Home > Technical Chat > verto clutches , std to uprated
stuart gurr - vmaxscart
Member #: 350
Turboing minis since '89
Supercharging minis since '04
there have been some problems in identifying standard and turbo , verto type clutches so heres some info :
borg and beck have been the original clutch supplier to rover since day one ,but have currently ceased production of the higher rated clutches, they differ from the luk and valeo types by having a pressed steel radial reinforcement round the spring piviot rivets, all companies list turbo , 1300 and 1000 types ,
Paint codes found on the spring fingers identify the b&b types : green 1000, brown 1300, dark blue mg 1300 ,light blue turbo,
luk and valeo don't use a paint code system ,
measuring the thickness of the spring ' fingers ' we find (+/-0.002")
0.065" is green rating 40 bhp,
0.075 is brown 60 bhp -mpi /spi ,
0.080 is ldark blue 75 bhp,
and 0.095 is light blue 95 bhp
there is also an extra heavy duty spring thickness of 0.105" which i have used at 140 bhp - in a mini-
also depending on whether the clutch plate to be used was a solid type 7.5mm thick ,or sprung type 6.5 mm thick ,the installed height may need checking - the .095 and the 0.103 are designed to use the solid plate ,
if the clutch has been used ,condition can be assessed by assembling the if the clutch /flywheel ,and standing on the release cup - the thickness almost translates to kg in wieght as a guide eg; green 65 kg should make the spring fingers 'pop' downwards releasing the grip on the clutch plate , turbo releases at 85 kg , and h/d one is at 95 kg with this test
some unscrupulous 'specialists' are currently selling the green and brown types as turbo -beware -
Edited by stuart gurr - vmaxscart on 12th May, 2005.
usefull info
TurboDave16V
Great Stuff Stuart!
Dangerous
Member #: 417
(+/-0.02"):
shouldn't that be =/- 0.002"
TurboDave16V
Hee Hee!
Member #: 350
and this weeks triva prize goes ..... dangerous!
edited !
Dangerous
Member #: 417
Actually it's trivia
TurboDave16V
ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing*
Edited by TurboDave16V on 18th Apr, 2005.
ho ho ho ho ho ho!!!
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Dangerous also scoops the most pedantic award!
Alex
AlexF
Member #: 350
- and becomes official proof reader for all our posts and replies !
giallofly
Member #: 164
The Stig..
Newport Pagnell
And wins tickets audience tickets to watch the weekest Link...*tongue*
That should be "weakest" Jon ....... lol *tongue*
Dangerous
Member #: 417
ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha
giallofly
Member #: 164
The Stig..
Newport Pagnell
My spelling has always been paw....*wink*
Dangerous
Member #: 417
Hmmmmm
I got light blue on a turbo an dark blue on a mg 1300
Member #: 350
again the proof reader has spotted it and i stand corrected - ultimately check thickness and or release wieght-
