| Home > 998cc > Blow Through Supercharged 1232CC A Series | |||||||
![]() 324 Posts Member #: 9441 Senior Member South Devon |
21st Nov, 2011 at 11:15:58pm
So I know it's not a 998 and it's not turbo but it is at least forced induction so I was hoping some of you guys could help critique and develop my proposed engine set-up.
21st Nov, 2011 at 11:22:53pm
For those who aren't on TMF this is my Clubman Estate project thread. |
22nd Nov, 2011 at 12:15:23am
I looked at your thread and found this:
22nd Nov, 2011 at 09:47:02am
You seem to be looking for a high horsepower result, but the M24 has a capacity and rev limit that will only provide enough air flow for 120hp.
Edited by Paul S on 22nd Nov, 2011. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
22nd Nov, 2011 at 10:14:47am
There's an orange clubman in the December minimag.
22nd Nov, 2011 at 10:38:48am
That's the one Jeff was talking about in the link ^^^.
22nd Nov, 2011 at 10:43:36am
I didn't read the link. It seems like that charger isn't great for our application. I'm assuming that VW only use them at low rev's as they have an internal gearing system to multiply the input rev's. I guess at more than 4500 it's spinning far too fast for it's own good. On 11th Feb, 2015 robert said:
22nd Nov, 2011 at 11:20:41am
This story of internal gearing seems to have come from someone at Eaton and seems to have traveled far and wide around the web.
22nd Nov, 2011 at 11:32:52am
looking at this picture, I think you might be right. Doesn't seem to be any internal gearing other that the sprockets to rotate the rotors.
22nd Nov, 2011 at 11:47:02am
Ackershly Andy those gears labelled "Vorgelege" do not look equal size. Not 1.93:1 though. Plus there is no need for 2 sets of phaing gears. Interesting. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
22nd Nov, 2011 at 12:30:31pm
If the top shaft is actually two parts, the top right gear driving the bottom right gives the speed increase (initially to the bottom rotor) then the left hand two gears keep the rotors in phase.....
Edited by Rod S on 22nd Nov, 2011. Schrödinger's cat - so which one am I ??? |
22nd Nov, 2011 at 12:31:25pm
On 22nd Nov, 2011 Rod S said:
If the top shaft is actually two parts, the top right gear driving the bottom right gives the speed increase (initially to the bottom rotor) then the left hand two gears keep the rotors in phase..... Agreed it doesn't look like 1.93 though. Well, stone the bleeding crows :$ My M24 is internally geared at 1.93:1. Looked at it in a bit more detailed, maked a point on the pulley and a point on one of the rotors and hey presto. Not readily apparent when you just turn the pulley back and forth, but it is geared. Doesnt change anything though. Still limited to 18000 rpm rotor speed. Edited by Paul S on 22nd Nov, 2011. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
22nd Nov, 2011 at 12:31:59pm
22nd Nov, 2011 at 11:15:15pm
Wow thanks for all the replies guys, I'll have to do some more reading on the finer details of the M24 and what it's capable of. I can't see me ever taking the estate round a track or down a strip in anger so limiting the revs shouldn't be an issue.
On 22nd Nov, 2011 Paul S said:
You seem to be looking for a high horsepower result, but the M24 has a capacity and rev limit that will only provide enough air flow for 120hp. Really, I would have considered 120 a good figure for a worked and charged 1300 road engine. If I'm honest I'd be happy with a really strong engine in the low/mid 90s. On 22nd Nov, 2011 Paul S said:
Personally, I would not risk wet manifold injection on a setup that will be prone to detonation due to high inlet charge temps. Would intercooling not help alleviate this or would it juts not bring the temp dow far enough? Edited by Tupers on 22nd Nov, 2011. |
24th Nov, 2011 at 04:48:41pm
If you are not looking for anything more than 90 odd hp, then you can reduce the cost of your engine considerably.
976 Posts Member #: 3228 Post Whore North of the Netherlands |
25th Nov, 2011 at 10:32:19am
Wouldn 't a T2 set-up get those numbers with not that much lag.
Dazed and Confused.... |
27th Nov, 2011 at 02:56:25pm
On 24th Nov, 2011 Paul S said:
Have you considered port injection, much safer than wet manifold, in my opion. I was chatting about that with my brother a few weeks ago but we wheren't sure if I'd run into issues with the fuel not atomising enough in the ports. I also had some worries about whether or not I could balance the amount of fuel going into each port. Once I've got the bulk of the engine built 'ie engine on gearbox with super charger mounted' I think I might ring SC and see whether they think their system could be adapted for my engine. This is the inlet manifold I'm thinking of welding a pair of injector bosses into.
Edited by Tupers on 27th Nov, 2011. |
27th Nov, 2011 at 03:25:20pm
Have a read of this:
27th Nov, 2011 at 10:20:53pm
Thanks for the link Paul, my brain fell out a few times while reading it but I think I'm starting to get my head around it. |
28th Nov, 2011 at 11:14:37am
It's best to be aware of the issues. There's some more here:
28th Nov, 2011 at 07:09:04pm
Do you know what the max inlet temp is you can run on a wet manifold system before you run into detonation issues?
28th Nov, 2011 at 08:00:52pm
I don't think that anyone can answer that as it depends on the AFR of the outer cylinders which you wont know until you build it, nor will you be able to do anything about it. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
28th Nov, 2011 at 08:42:52pm
This should interest you:
