Home > How To > Enlarging head chambers to lower CR
Paulham
Member #: 9654
NW London
Does anyone know of a guide of enlarging the chambers on a standard 998 head to lower the CR?
I've searched online but haven't had much luck, maybe I'm using the wrong keywords/terminology?
Paul
Buy David Vizard's book, Tuning the A series engine. That'll get you going.
Paulham
Member #: 9654
NW London
I have done already, although not had the time to sit down and concentrate.
So your saying the details are outlined in the book?
Paul
Will
Member #: 11091
Urmm having difficulty on finding this info out myself
Don't have the yellow bible myself but any basic pointers for a complete novice?
Or does anyone know anyone that enlarges the chambers on my cylinder head?
easiest and best thing is to send it to someone, TurboPhil and Benross on here both do good head work and at good prices too. ball park your probably looking at 100 quid to get the chambers done.
What casting are you working with ?
The Vizard book shows you where to remove material in reference to valve size. What kind of volume do you need ?
Phil.
Rammie2000
Member #: 10190
belgium
Its in there. Just a bit complicated becaus he shows the different things with different valve suzes on 1 drowing. But once you get it piece of cake. I use a dremmel few years of my life becaus of the dust and 3 to 4 hours a chambre... really... if you arent in a shitty land where everzthing seems to be costing more then gold like i am... just get it done by a pro.
Hats of to you Rammie. That's determination, 3-4 hours a chamber with a dremel !! Wow.
Phil.
get a router and a carbide bit FFS!
Will
Member #: 11091
I've sent benross a message, I think rammie is right
No skill + no tools + no guide = go pro!
Rammie2000
Member #: 10190
belgium
yes on a na 998 head. im doing the turbo been 6to 7 hours now to get it big enough ( on first chamber) pics on here somewhere. its based on how your avatar looks. so aprox 24 hours to do the whole head but if getting it done here would cost me 500 euro at least. not rich but if i want it i go for it... hahaha
Phil.
If you don't have access to a compressor/die grinder you'd be better off getting a cheap flexible shaft for a drill, though no ideal, with proper carbide bits it would still be much quicker/easier than with a dremel.
Phil.
Edited by Turbo Phil on 9th Jan, 2017.
Jamester101
Member #: 11517
Hi Phil - you website seems to be down, will it be up again? It's my bible at the mo *smiley*
Yes, eventually. It's getting reworked, but other things are taking priority at the moment.
Phil.
Jamester101
Member #: 11517
Ok - great, it's a project that will probably take a year or 2, I'm hoping to build a 1275 turbo using the principles you describe. at some point I will probably be coming to you for some head work etc
