Home > 998cc > best head and cam for my 998?
coopdog
Member #: 9628
im looking to turbo in the long run but for now i want to change my head and cam,
i can get hold of a 12G295 and a 12G240,
which would be the best??
and i want to turbo it sometime next year so i dont want to mess with the cr to much :/
and i have been told mg metro cam is the best for a every day, fast road car??
thanks
callum
Unless you want to pocket your block or go for monster power, I'd stick with the 295.
Also the MG Metro Cam would be a good choice.
coopdog
Member #: 9628
ok thank you :)
would the 12G295 need to be skimmed??
That depends on your application. I suggest you do some reading on the subject.
The search button is your friend.
coopdog
Member #: 9628
ive looked but no information on i want to know :/
I beg to differ.
coopdog
Member #: 9628
well i have looked, ive typed in do i need to skim a 12G295, and 12G295 and look through loads of topics but none say about if it needs to be skimmed
I'm sure it does say in hundreds of topics that the standard 295 with 28cc chambers will give 9.3:1 CR with flat top pistons and that this is suitable for 12psi (or more with good fuelling and IC).
If not, then this one now does!
coopdog
Member #: 9628
thank you will :)
min79GT
Member #: 910
Thank you for your help guys cheers
1380
zerocool_jj2000
Member #: 9439
stoke on trent
Cant you receed the valves into the head to prevent them from hitting the block instead of pocketing the block? i remember K Calver doing so. Worked ok for him, not on a turbo application mind..
