Home > 998cc > carb settings
softlad1988
Member #: 8462
I have just rebuilt my standard turbo carb but when i took it apart there was no jet or needle! what is the best position 2 set these so that my car will run? The car is a 988 turbo using a modded standard head and a stock cam with an intercooler. the needle is a BDD
Hard to say. But using the BDD, wind the jet right up to the top, then back dowm 2 1/2 turns.
This will get it started, but it's no guarentee that it will be right for the whole rev range.
Read the guide to polishing needles on here.
softlad1988
Member #: 8462
i got it running set at that so thanks! now i have the fueling ok at idle but have taken it down the road but it doesnt seem 2 be boosting at all! just make noise lol! any ideas?
turbominij
Member #: 2104
Essex - UK
boost leak?? *tongue*
chances are there is a vac pipe off or something easily done if its just been put together.
"Tuning should be a compromise between what is possible and what is necessary"
10)Thou shalt always quest for more power
Check that the actuator is shut.
Other common mistake is to have blocked the hole to the float bowl from the plenum.
softlad1988
Member #: 8462
i have blocked the plenum hole and that checked that the acuator is shut but still no difference! wat should the fuel pressure be at idle? could i have it set to low low so when it starts to boost there is not enough fuel??
Fuel pressure should be 3.5 - 4 psi at idle
softlad1988
Member #: 8462
ok and how can i make sure it raises correctly as the boost increases?
softlad1988
Member #: 8462
as has anybody got a meag jolt map that will help it run better? its a standard 998 with a standard cam and i modded standard head and a t2 turbo on a homemade manifold. *frown*
wez
Member #: 9271
Stoke on Trent
did you check that you haven't blocked the hole from the plenum to the float bowl as wil h said?
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
softlad1988
Member #: 8462
sorry i thought you meant poppet valve hole! where is this hole?
If you look at the rear face of the carb. There is a small drilling on the right hand side near the bolt holes. Should be a matching hole on the planum. Make sure the gasket hasn't blocked it.
softlad1988
Member #: 8462
right! i now have the cer boosting but not until about 4000 rpm! :( and wen the car is at tickover it is not running on number 1 cylinder at all! i have done a compression test and all cylinders are the same! i have checked my tappets and the only thing i can find is there is a weak spark at that cylinder so i have ordered a new coil pack and HT leads! any ideas guys as you have been a massive help so far! :)
What turbo is it? Boost at 4k sounds OKish...
What turbo are you using?
softlad1988
Member #: 8462
a t2 in standard trim
And are you driving the car or just revving it on the spot?
softlad1988
Member #: 8462
driving but because it is not running right i think it is not boosting correctly!
softlad1988
Member #: 8462
Get it setup on a rolling road. you risk damaging it if you don't
softlad1988
Member #: 8462
any ideas why it it is not running on cylinder 1?
dodgy plug or lead.
softlad1988
Member #: 8462
i have found out why it was only running on 3 cylinders! the inlet maifold was damaged on number 1 and 2 cylinder! :( i have changed it and problem sovled! thanks guys! massive help once again! :)
