| Home > 998cc > 998 turbo build | |||||||
22 Posts Member #: 9602 Member Ipswich - East Anglia |
5th Oct, 2011 at 04:59:45pm
I have finally narrowed down a rough sketch of the build i want for my 998 turbo..
5th Oct, 2011 at 05:14:40pm
4 pin diff ?
Edited by Paul S on 5th Oct, 2011. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
6th Oct, 2011 at 01:08:50am
4 pin diff!! knew i forgot something..
6th Oct, 2011 at 09:12:52am
The unskimmed 12G295 chamber volume is 28cc. Used with flat topped pistons gives you around 9:1 compression which will be fine up to 12 psi with a good intercooler.
6th Oct, 2011 at 01:31:38pm
Do well flat tops with an unskimmed or slightly skimmed 295 head
![]() 392 Posts Member #: 5702 Senior Member Cornwall |
6th Oct, 2011 at 07:45:58pm
On 6th Oct, 2011 black n yellow said:
4 pin diff!! knew i forgot something.. you reckn flat top pistons with a 295 head? what sort of boost will that allow me to run? 3 pin diff
12 psi at 9:1 will be ideal for fast road application, i wouldnt go straight cut if you have to do a lot of mileage. |
7th Oct, 2011 at 12:30:11pm
fair play i see what ur saying about high milage and sc gears.
![]() 774 Posts Member #: 6724 Post Whore Wootton Bassett |
7th Oct, 2011 at 12:56:27pm
have a look at my build thread below |
7th Oct, 2011 at 03:36:42pm
Standard regulator will be fine. |
