| Home > 998cc > 998 low comp pickup engine | |||||||
25 Posts Member #: 546 Member Cambridge/Peterborough |
19th Sep, 2011 at 08:52:53pm
Hi guys,
1976 mini pickup |
19th Sep, 2011 at 09:38:06pm
I'm running upto 10psi with a low comp 998 running 8.7:1 (with turbo phil sorted 295).
19th Sep, 2011 at 09:51:46pm
Thats not bad for a 42 year old lump! Have you had it on a dyno? I wonder if its worth doing much to the bottom end then... Will have to see what it looks like when the heads off.
1976 mini pickup |
19th Sep, 2011 at 10:42:16pm
Yep it was all setup by my local rolling road. That's what I mean by the setup is more important. If the fueling or timing is wrong its more likely to end up with a set of liquid pistons. Mines been running with a 40 year old bottom end with 60k on the clock since 2007. I will admit it only does about 3 k a year Inc a coup,e of track days. I run a supercharger and I don't care the TB is on the wrong side.
20th Sep, 2011 at 07:39:56am
You won't need to do anything special to the bottom end.
![]() 1137 Posts Member #: 1450 Post Whore Near Paris - France |
21st Sep, 2011 at 08:23:23pm
8.3 pistons and 295 head will need either a lot of skimming of the head or a CR good enough for 30 psi ...
Rusty by nature
They said "That sounds rough mate." I said "Cheers it cost me a fortune to make it sound like that!" |
21st Sep, 2011 at 10:05:52pm
I was wondering how much lower a 12g295 head would take the compression ratio. I guess if all the exrta volume is in the pistons i could run a more normal head ( with unleaded seats!) and still keep a low comp. I'll measure the camber volume when the head is off and see if its sensible
1976 mini pickup |
21st Sep, 2011 at 11:35:35pm
On 20th Sep, 2011 wil_h said:
You won't need to do anything special to the bottom end. 8.3 is low though. I run 9.3:1 and over 12psi no problems. I run a supercharger and I don't care the TB is on the wrong side.
22nd Sep, 2011 at 08:06:16am
Yes I run an IC, air temp rarely go above 35 acording to the sensor. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
22nd Sep, 2011 at 09:29:07pm
998 non cooper head are 24 something, thats 10,3 whith flat top piston
Rusty by nature
319 Posts Member #: 1742 Senior Member essex |
23rd Sep, 2011 at 03:51:44pm
202 heads unskimmed have more volume its 26 cc but i have also had a 202 head that was unworked that had 28cc. It is better to measure your dish if poss and deck height at tdc then calculate your compression ratio as i have rarely had a standard engine come up to spec. The most recent one i took apart had a difference of 6thou on the deck heights. My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901 |
23rd Sep, 2011 at 04:18:41pm
JLay, you are right.
Rusty by nature
