Page: |
Home > A-Series EFI / Injection > Lambda Sensors & Coolant sensors | |||||||
57 Posts Member #: 8939 Advanced Member Banbury, Oxfordshire |
30th Aug, 2011 at 12:05:27am
hello,
514 Posts Member #: 2104 Post Whore Essex - UK |
30th Aug, 2011 at 01:34:41pm
i have put mine near the gearstick easy to get the cable in to the car. inovate said it would be ok pritty much anywhere as long as its after the turbo
16540 Posts Member #: 4241 King Gaycharger, butt plug dealer, Sheldon Cooper and a BAC but generally a niceish fella if you dont mind a northerner Rotherham, South Yorkshire |
30th Aug, 2011 at 01:42:51pm
I'm putting my ECU coolant sensor where the heater tap is in my head (I'm dry decking so lots of flow there) and my additional temp gauge in a hose joiner in the top hose.
i tried putting soap on it , and heating it to brown , then slathered my new lube on it |
30th Aug, 2011 at 01:50:11pm
I've got temperature sensors in the thermostat housings on two cars. Works Ok for me but in the head would be best for the ECU. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
1434 Posts Member #: 8466 Post Whore Mansfield |
30th Aug, 2011 at 02:00:00pm
Wolfy, Ive Have a AEM Wideband gauge and Sensor for sale, Its only done a few hundred miles. I lost the sensor during my rebuild, so bought another kit, only to find it packed away safely. I comes with Black face and bezel, Im after £110, I also have a matching Boost Gauge for only £70 & Oil pressure gauge £70. £200 for the lot. Class C 3rd Place Avon 2011 14.18 @101mph |
10021 Posts Member #: 1456 Mongo Barnsley, South Flatcapshire |
30th Aug, 2011 at 02:24:16pm
Matt send me some pics mate! If something is worth doing, it's worth doing half of. |
30th Aug, 2011 at 03:17:05pm
The sender for the ECU really has to be before (below) the thermostat as the ECU needs to know how fast the engine is warming up to adjust the mixture accordingly.
30th Aug, 2011 at 09:44:26pm
Is there an option where i can run the gauge and ecu from the same sensor? |
11046 Posts Member #: 965 Post Whore Preston On The Brook |
30th Aug, 2011 at 10:58:08pm
On 30th Aug, 2011 Rod S said:
The sender for the ECU really has to be before (below) the thermostat as the ECU needs to know how fast the engine is warming up to adjust the mixture accordingly. I'm with you rod, its text book page one! There is a certain engine tuner that fits the coolant sensor in the very top of the thermostat housing, above the thermostat On 26th Oct, 2004 TurboDave16v said:
30th Aug, 2011 at 11:15:34pm
The AEM Gauges have 0-5v outputs for the ECU. Class C 3rd Place Avon 2011 14.18 @101mph |
31st Aug, 2011 at 12:06:05am
31st Aug, 2011 at 09:38:51am
the inovate lc-1 controller has 0-5 for the ecu aswell
31st Aug, 2011 at 09:44:49am
The sender for the ECU really has to be before (below) the thermostat as the ECU needs to know how fast the engine is warming up to adjust the mixture accordingly. I'm with you rod, its text book page one! There is a certain engine tuner that fits the coolant sensor in the very top of the thermostat housing, above the thermostat Are you both saying that there is zero heat transfer across the thermostat even when closed? I think not. As the coolant sensor is only used during warm up, I personally think that it is not that critical. I've been using a temp sensor in the thermostat housing for several thousand miles now without issue. However, we have put the sensor in the head on the latest build. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
31st Aug, 2011 at 11:09:45am
Obviously there will be some heat transfer but it certainly will be a long way off the actual bulk coolant temperature until the thermostat starts to open (unless you have a leaking thermostat or one drilled with holes).
31st Aug, 2011 at 03:00:24pm
And that is the correct way to do it. ECU sensor in the head.
31st Aug, 2011 at 07:11:39pm
There is nothing complicated here, and I would rather the tamp gauge be a bit hazey rather than the coolant temp sensor for the ECU.
31st Aug, 2011 at 08:04:26pm
On 31st Aug, 2011 Sprocket said:
then fit the gauge temp sender in the thermostat housing. Its that simple! But it is not though, is it? You cannot fit a 5/8 UNF sensor with a tapered seat in the thermostat housing without some fabrication and welding. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
31st Aug, 2011 at 08:38:39pm
Lets not bent out of shape here,
9502 Posts Member #: 1023 Post Whore Doncaster, South Yorkshire |
31st Aug, 2011 at 08:47:54pm
if your tuning the warm up enrichment which i presume we would, does it really matter where the temp sensor goes with regards before or after the stat, both will see the temp rise and allow you to map the enrichment to it??
Yes i moved to the darkside
31st Aug, 2011 at 10:18:50pm
On 31st Aug, 2011 Rod S said:
And if you choose to put the ECU sender before the thermostat in an A series head, you will most likely have to sleeve/bush the head as it isn't metric. (I did). SPi sensor will fit in the standard temp gauge sender hole On 26th Oct, 2004 TurboDave16v said:
Page: |
