Page: |
Home > A-Series EFI / Injection > what you think spi to ms2 set up?? | |||||||
40 Posts Member #: 8907 Member |
22nd Aug, 2011 at 10:55:39pm
hi just running this past you to see what you think going to run my spi 1293 n/a 286 cam with MS2/Extra (std one form diyautotune.com) mini mpi coil, 36-1 triger wheel and jenvey 45mm http://www.jenvey.co.uk/home/twin-throttle...m-single-tbsxxi but whats bets to use for Idle control, stepper on jenvey (if one fits) or iac (in a alloy block and piped up) Edited by bhpmini on 22nd Aug, 2011. ms2 is beyond me come back carbs all is forgiven why did I decide to modify a spi mini to late to turn back now so please put up with my stupid question and humour me |
22nd Aug, 2011 at 11:11:10pm
Which intake manifold are going to use? The problem with this setup is that the injectors are going to be too far and in a bad position for correct port injection with sequential injection (and the siamese code). And you can't use it for a wet manifold setup since each injector is only seeing one intake port.
22nd Aug, 2011 at 11:21:57pm
was going to use weber manifold and for wet manifold still getting my head round it even after reading lots of books lol then when up and running and saved some cash up was going to get a v max supercharger kit and use jenvey on it fits weber manifold Edited by bhpmini on 22nd Aug, 2011. ms2 is beyond me come back carbs all is forgiven why did I decide to modify a spi mini to late to turn back now so please put up with my stupid question and humour me |
857 Posts Member #: 1778 Post Whore Northants |
23rd Aug, 2011 at 10:49:48am
Have you already purchased the MS2?
Edited by sturgeo on 23rd Aug, 2011. |
23rd Aug, 2011 at 11:59:39am
The benefit of the Mikunis is that we can get them close to the head and at 45 degrees so that the injector points straight down the port. We will add length to the runner upstream of the TB to get decent torque.
23rd Aug, 2011 at 01:12:04pm
Yes got ms2
23rd Aug, 2011 at 01:33:22pm
Have a read:
Edited by Paul S on 23rd Aug, 2011. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
27th Aug, 2011 at 12:16:19am
thanks for the info jenvey paln is scraped for now will get it running on spi set up for now just to speed up getting it on road then?????? lol ms2 is beyond me come back carbs all is forgiven why did I decide to modify a spi mini to late to turn back now so please put up with my stupid question and humour me |
31st Aug, 2011 at 12:08:40am
got a few questions (not doing to well with all this ms stuff) going to run std spi set up just till i get my head round making a port injecting blow through supercharger set up looking for 130/150hp (or if that fails will just get a suck through kit lol) so whats best to use (pro/con you have found) high or low injectors dont know wether to fit/need a Peak&Hold Injector Driver Board (got std ms2) and whats best to run/wire up vr or hall for cam sensor (searched the site but not much info on whats been used or made)
Edited by bhpmini on 31st Aug, 2011. ms2 is beyond me come back carbs all is forgiven why did I decide to modify a spi mini to late to turn back now so please put up with my stupid question and humour me |
31st Aug, 2011 at 01:20:45pm
From what I can see don't need cam sensor or any add on for spi or suck supercharger ms2 is beyond me come back carbs all is forgiven why did I decide to modify a spi mini to late to turn back now so please put up with my stupid question and humour me |
31st Aug, 2011 at 01:47:57pm
If you are doing "wet manifold" ie, a non sequential system, then you don't need a cam sensor.
31st Aug, 2011 at 09:02:54pm
Now got a fully built ms2, kit from diyautotune so think it will do both
Edited by bhpmini on 2nd Sep, 2011. ms2 is beyond me come back carbs all is forgiven why did I decide to modify a spi mini to late to turn back now so please put up with my stupid question and humour me |
1st Sep, 2011 at 08:13:14am
Well, from what you have just said, there are a couple of points to consider.
1st Sep, 2011 at 06:24:02pm
got this ms2 http://www.diyautotune.com/catalog/megasqu...case-p-119.html (friend built it)
Edited by bhpmini on 1st Sep, 2011. ms2 is beyond me come back carbs all is forgiven why did I decide to modify a spi mini to late to turn back now so please put up with my stupid question and humour me |
1st Sep, 2011 at 06:54:05pm
On 31st Aug, 2011 bhpmini said:
got a fully built ms2 from diyautotune so think it will do both So fully built from DIYAutotune ??? On 1st Sep, 2011 bhpmini said:
(friend built it) But maybe not.... On 1st Sep, 2011 bhpmini said:
beginning to think i should have got a Specialist Components etc Plug-N-Play ecu lol (but no rolling road i know wll map them) I think John K would be equally confused by now.... I really think you need to change your signature. (EDIT - Typo) Edited by Rod S on 1st Sep, 2011. Schrödinger's cat - so which one am I ??? |
2nd Sep, 2011 at 12:05:12am
I knew what I ment as its the same thing really now got a fully built ms2, was a kit from DIYautotune and have change signature I think that's better lol Edited by bhpmini on 2nd Sep, 2011. ms2 is beyond me come back carbs all is forgiven why did I decide to modify a spi mini to late to turn back now so please put up with my stupid question and humour me |
2nd Sep, 2011 at 07:43:19am
To be fair, any RR should be able to map any ECU. If I had a RR I'd just say, "yeah, no problem, but it might take a bit longer as I'll have to learn the system, might cost a few extra pennies?"
11046 Posts Member #: 965 Post Whore Preston On The Brook |
2nd Sep, 2011 at 10:58:26am
John Buddy, i'll come round one evening next week and go through the whole thing for you.
2nd Sep, 2011 at 02:12:08pm
You know me fretting is my middle name will ring you later what would I do with out u big big thank you (you all way make it sound easy ) ms2 is beyond me come back carbs all is forgiven why did I decide to modify a spi mini to late to turn back now so please put up with my stupid question and humour me |
Page: |
