Home > A-Series EFI / Injection > just a couple questions
edit:maybe wrong section :/
right im having a couple problems if anyone could help out id appreciate it
what size gap should i get between the vr sensor and 36-1 wheel?
now i have checked it my self on the net but neither way for me seems to make a difference so which way does the sensor need to be connected?
the grounding/ sheilding cable is that used as the -ve on the vr sensor? some threads on another forum seem to say no!!! lol
im running 2 coil waisted spark with D14/D16 as the 1st and 2nd coils but should the LED's (D14/D16) flash when the coil fires?
and i have now figured out how to log the toothed wheel input but its too late to fire it up to test anything
basically im getting nothing when cranking *happy*
cheers
Edited by Brett on 31st Jul, 2011.
yeah the LED's should flash as the coils fire,
you might need to tweek the pots.
Yes, LEDs flash alternately as each half of the coilpack is fired so it's a good indicator if the VR is working (but you have the RPM indication and synched light in Tuner Studio to tell you that anyway and you have the tooth logger to check with, as you say at the end).
On the basic MS2/3 the VR input is a bit of a fudge, hence the trim pots to try and get around all the variables (they will most likely be your problem as Joe says). But because the input circuit is very basic, VR- and the sheilding around the cable are basically the same, ie, they are both connected to ground at the MS end (although at different pins on the connector). That doesn't mean you should use the shielding as the VR- connection as a good cable will be a twisted pair inside which minimises noise affecting the VR+ and VR- (ie, any noise is balanced out).
I've found 0.8 - 1.0mm is best gap for me.
One final point, just because you have (presumably) tested it on the JimStim and had a good signal, the pot settings may well have to be completely different on a real VR sensor in the car (mine certainly do.....)
Personally, If it's a self build, I would leave the whole VR circuit out and use Jean's latest board, a true VR+/- input with no pots to worry about and much more sensitive (look in the "build manual" thread).
EDIT - I missed one point, have you got the VR+ and VR- the right way around at the sensor plug ?
EDIT2 (pin connection, I had to look it up in my notes) - For the VR, look at the junior timer connector (plug) that goes onto the VR sensor. If it is new it will have "1" and "2" moulded into the plastic part of the pin sleeves. "1" is positive.
If secondhand or unmarked, hold it with the wires towards you, the plug part away from you and the metal release clip on top, "1" is the righthand side.
Final point (don't take this the wrong way) but is it set in the software for spark A being D14 ?
Edited by Rod S on 1st Aug, 2011.
cheers guys exactly the info i was looking for
an update, the vr sensor works perfect very clean signal ( after a pot twiddle or two)
i asked about the sheilded cable because i bought the ready built loom mainly because it was a very good price imo with the cable lables printed on and stuff..
the VR -ve is wired into the the sheilding on that loom so i copied it again on my loom (bringing me onto my next point lol) although good value for money the loom didnot include all the extra wires (eg spr1-4) so i ha to use my spare plug and make another as it did not have pins for the spare wires ether lol
the other upgrades and add ons for ms will be a winter task *wink* just want it ready for mitp
jimstim... nope *happy*
vr connections double checked and are fine
all software setup as per the build guide but i am still not getting the flasshing LED's :/
coil pack yet to be wired, should the LED's flash even with no load on the end of the wires with no jimstim its going to be a case of wire it up and see i think everything else checks out dont see where i would have made a mistake
edit: im just getting the log view now as i took some logs when playing :) does it log the coils firing at all?
Edited by Brett on 1st Aug, 2011.
If it's a "standard" build (ie, the LEDs were built and the coilpack resistors and ignitor chips added on top of them, which would be the normal way of doing it) then yes.... The LEDs are driven by the CPU output so if the CPU is set for wasted spark and D14/16, they will flash.
The resistor. ignitor chip is just an extra load on the CPU output ports, the output ports should flash the LEDs irrespective....
Tooth logger - I've never actually used it (sorry, mine worked first time...) but I believe it just logs the inputs to the CPU, not the outputs.
If you don't have a JimStim you really need to connect it to the laptop (with it in the car) and see if you get cranking RPM and synch in TunerStudio/MegaTunix.
Also make sure your coilpack settings (esp the "inverted" setting and dwell time) are correct before you actually start it for real or you could fry the coilpack.
The wiring on "standard" looms is questionable - the lack of SPR1-4 just shows it - but I'm surprised they didn't bother to do the VR signal right..... possibly the standard one assumes Hall rather than VR ???
I made my own loom from day one.... and I've since moved on to a proper connector anyway.
jbelanger
Member #: 831
Montreal, Canada
DIYAutotune has a new loom which includes the spare pins and has the correct VR wiring. This was a sore point for many users and they have responded in the end.
It still doesn't correct the VR circuit shortcomings or use an automotive connector but those are different issues.
Jean
http://www.jbperf.com/
well an interesting day messing about getting nothing ( excepts some very nice wiring *happy* ), whilst browsing the various forums searching for similar problems i discovered another firmware update ( dunno how long its been out for) msextra 3.1.1 (was 3.1.0) all problems sorted it would seem just like that
happy, fingers crossed for the first fire up on ms tomorrow afternoon :)
edit, and changing the shielded cable first job on the list, including beefing up the earth wires and coil-out wires im unsure what sort of current they will be handling but they feel a tad thin compared to the oem thickness wires on the coil pack connector
Edited by Brett on 2nd Aug, 2011.
That sounds a bit strange - I'm on a much earlier version of the firmware (why change what works is my view).
What actually are your problems Brett ??
EDIT - just seen your edit.... how exactly are you taking the coilpack wires out and how have you got the ignitors installed ???
Edited by Rod S on 2nd Aug, 2011.
my problem was zero output on the coils, i flashed back to the old firmware just too see and yep stopped working again back on 3.1.1 and it works very strange indeed
where can i get a copy of the old firmware's?
the ignitors are on the std heat sink inside ms and they come out on pin 36 and 6 i have beefed up the traces on the board for pin 6 all done by the build guide really
over the winter i intend on a few upgrades
I don't know if this is an "official" way but it works.....
On the MS-Extra forum they allways post the link to the latest version (currently 3.1.1) but instead of clicking on the link and going straight to that zip file, I type in the URL for the parent directory which will give you this
http://www.msextra.com/doc/ms2extra/files/
and under that directory, the directory release/ will give you the most recent ones and the directory alpha/ gives you all the previous ones.
Obviously the link they post on the forum is the newest file name within the release/ directory
The only reason I can think as to why an earlier version didn't work for you is that an awful lot of the default settings need changing in the early versions for an A Series setup (but that could well be true of the latest version too - I'm still on one of the 3.0. something alpha versions, I haven't looked at the 3.1 series).
Glad to here you beefed up the tracks for the ignitors. Personally I still think that is a bit of a fudge and as I didn't have a spare pin anyway I ran suitably rated wires (including the ignitor chip grounds) out to an additional external connector.
But if you got it working on the later firmware, then obviously hardware wasn't the issue.
EDIT - missed the current question.... about 5A but only for short periods of time, ie, when the coil is charging. That's why they can get away (just) with a single pin on the DB37 and beefed up tracks.
BUT - depending on which ignitor chips you are using and what current you have the coilpack fused at, if the coilpack develops an internal fault, the Fairchild and International Rectifier chips will easily sink 20A. The correct rule with wiring is not to rate it at the current it normally operates at, but the current it will draw under a fault before the fuse blows.
Edited by Rod S on 3rd Aug, 2011.
Carl S
Member #: 1761
Stalker
There were a couple of versions of the 3.0 code which were dodgy then, as I had a revision of 3.0 on my box which would cause the sync loss counter to rise steadily all the time, and would hard reset itself whilst doing nothing at all(power on, no activity).
I can't remember the revision but if I find it on my PC then i'll put it up here.
Changed to 3.1.1 and bingo, no more sync loss.
been doing a couple bits today, mainly to find tdc and put some marking on so they can be checked with a timing light
does this method sound right?
plug out on no1 cyl screwdriver in (after i removed the washer *happy*)
feel with the screwdriver where tdc is, put a mark on the pully and a mark on the timing cover at the same spot ( ie tdc markings)
i then fired it over using a 0 deg static timing the marks in theory should line straight up on the timing strobe yeah?
they only lined up when i set the crank offset to 81 deg btdc ( where it was 90)
does that mean the bracket is 9 deg out?
or is this method bollox
also i can see on the ignition map the point its is reading during running, say the map says 24deg advance for instance the dial gauge on the display (labled igniton advance) says 28deg its always 4 more than the map states
edit, i should add it does this now but did not yesterday
any pointers? all in tunerstudio
Edited by Brett on 4th Aug, 2011.
I wouldnt be happy with finding TDC like that,
What I have done in the past is smashed the porcelain out of an old plug and put a bolt through it so it stops the piston coming all the way to TDC, you then gently wind the engine over by hand untill the piston kisses the plug thingy, mark the pully, then wind the engine back the otherway till it touches again and make a mark, hen you ad another mark half way between the two you just made, the third mark is your accurate TDC mark, you can then make it peranent with a file or somthing and loose the other two.
also if you can do the marking on the outside rim of the flywheel it will be loads more accurate.
also depending on your strobe it may read double if its a digital one.
