Home > A-Series EFI / Injection > Weber DCOE 40 Flanges
alaskanow0
Member #: 8466
Mansfield
Anybody know where I can get hold of some alloy flanges for my 7 Port injection plenum as below?
Stole the picture from Wolfie's build
Make sure you get 40's as I had loads of greif with 45's not lining up...
You'd assume that the hole are on the same centres... but it seems not.
If I was doing my intake again I'd seriously consider doing it in steel and braze it together because as theoneyedlizard & wintersurfer will tell you I blew the welds right off!
http://www.ebay.co.uk/itm/DCOE-CARB-THROTT...=item1c1d378dc9
