Home > A-Series EFI / Injection > MegaSquirt for 7 Port
alaskanow0
Member #: 8466
Mansfield
Hi Guys,
Im currently planning my alloy 7 port build, Im going to be running a custom alloy welded plenum and a single throttle body, using T2 turbo, 12psi boost @ 9-1CR. etc. This is my first attempt at injection, so my knowledge is very limited.
Ive been looking at different ECU's, but it seems alot of people on there are using MSquirt, Ive been on there website but not sure which ecu is best suited. Im also concerned that my rolling road is not familar with MS.
Whats the advantages / disadvantages of the Mega Squirt system.
Do you have to build your own?, Are they easy to work with?, Does it work with my Ford coil Pack/ Edis?
Thanks Matt
Edited by alaskanow0 on 24th Jul, 2011.
The Megasquirt ECU was originally developed for DIY use based on fairly simple batch injection.
But it has long since evolved....
There is still a fair bit of DIY involved but the MS2 with simple modifications will run fully sequential injection for any 7/8 port engine.
Some of us are using it with the MS2-Extra siamese code that Jean wrote specifically for the 5 port engine but once the small modification is done to the CPU daughterboard it does sequential on either 5 port or 7/8 port.
Beyond that there is MS3 (which Paul is now using) that gives 8 channels (7/8 port sequential staged injection).
If you stick with MS2,
Avantages - will run fully sequential on 5 port (siamese code) or 7/8 port (normal sequential). also much cheaper than any of the other so long as you accept a fair amount of DIY needed.
It can also be built to run 4 channel low z injectors.
Disadvantage - need for some DIY to release the full potential.
You don't have to build your own but there are only a couple of (reputable) people in the UK who build them and you would need to specify the "extras" that you need.
If built to do so, it runs the normal Ford coilpack withOUT an EDIS module, it just drives the coilpack direct (or COP or anything else...)
Have a look here.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=408438
alaskanow0
Member #: 8466
Mansfield
Thanks Rod, Ive just read Paul's execellent write up. Just got a couple of questions;- Will the 7 Port be batched, semi or fully sequential. I was planning on running just Crank sensor pickup. If only batch, how do I install a cam sensor? Is sequential more superior? Does MS have control boost based on revs / gear?
Thanks Matt
I wrote most of that..... Paul just took the credit :) :)
You can't do fully sequential (5 port siamese or 7/8 port sequential) without a cam (phase sensor).
If you have an MPI block/cam it's already there but the simple DIY solution for the majority of engines is a Hall switch or opto switch in a cut down dizzy. Paul's latest version is a hall switch built into the back of the timing chain case (looking at the big sprocket) but the modified dizzy case is probably the simplest answer.
sturgeo
Member #: 1778
Northants
We are moving everything over to MS3X in due course. You can buy one of these fully assembled from diyautotune for $640.
If you plan on using the ford coil pack you'll also need one of the external spark driver boxes, available from people on msextra i believe. We have chosen to go with Coil Near Plug so drive them directly form the MS.
With the MS3X you get almost any feature you could want out of the box. launch control, gear dependant boost control, traction control, progressive nitrous, switchable tables, anti-lag, all without any modifications. They also have programmable outputs so can drive fans, pumps, or anything you can think of under a certain condition (for example coolant above 80 degrees)
Also another brucey bonus is the msextra forum, a huge knowledgebase as MS's are so widely used across the world, if you want to know how to do something, odds are its alerady been done so just search.
The software (TunerStudio) is easy to use, and like all other systems has tables for ignition, and fuel. Any RR that wont work with the software is most likely trying to sell you something.
alaskanow0
Member #: 8466
Mansfield
Sorry Rod, Your execellent write up *blush*. Can you recommend were to buy one built and what features i will require. I like the idea of twin lambda, as i have a spare AEM gauge kit & been wondering if the outer cylinder would run richer, due to raduis of port. I fancy the DTA S80 for the datalogging, but not for £1k. If I ditch the Ford Coil pack from my megajolt, what coil do I need?
I was only joking, Paul and I have been working on the "build guide" together.
It just didn't seem there was enough interest for it to go anywhere.
Not sure of the best people to get one built (i've allways done my own) but I think you will find them on the MS-Extra forums as the only two UK code writers (Paul can answer this better than me but I think he's away at the moment). But they are really easy to DIY build.
You don't need twin lambdas if you are doing 7/8 port...... the only reason we use twin lambdas for the five port is because of charge robbing on siamesed ports...... Charge robbing doesn't happen on 7/8 ports so a single lambda will be fine (so long as it's wideband).
You don't need to ditch the Ford coilpack, it works fine on MS2 so long as it's built to run the coilpack - it's the EDIS module you ditch.
Datalogging is via the MS2 / TunerStudio or various other platforms if you want to use them.
Also the MS3 can datalog to an SD card :cool:
Glad you said that :)
