| Home > 998cc > 998 turbo build | |||||||
![]() 126 Posts Member #: 9515 Advanced Member ireland |
15th Jul, 2011 at 08:51:26pm
A job worth doing is a job worth over doing |
15th Jul, 2011 at 08:54:08pm
Oh ya, i have a metro turbo fuel regulator and fuel pump too. A job worth doing is a job worth over doing |
194 Posts Member #: 1296 Advanced Member Milford Haven Pembrokeshire |
15th Jul, 2011 at 11:40:40pm
Why not go 1275cc?
15th Jul, 2011 at 11:55:38pm
On 15th Jul, 2011 mini23 said:
Why megajolt? Why intercooler? If you run high boost to need an intercooler, your'l need to upgrade lots of other parts. mjlj imo is the single best upgrade you could buy intercooler is a good idea for increased boost other upgrades shouldnt be needed as even a quite hot 998 wont be pushing anywhere near a 1275 unit Wil h and Ben h have the dogs danglies of 998, read there build thread they have a website too Edited by Brett on 16th Jul, 2011. Yes i moved to the darkside |
![]() 825 Posts Member #: 2208 Post Whore Essex |
16th Jul, 2011 at 02:54:49am
mj yes, it helps and runs better from what ive seen, e.g. start up and no run on plus you can map it to your build.
16th Jul, 2011 at 08:03:41am
Not sure what you are saying here. are you suggesting that there is no need for an IC or MJ?
Why not go 1275cc? Why megajolt? Why intercooler? If you run high boost to need an intercooler, your'l need to upgrade lots of other parts. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
16th Jul, 2011 at 08:13:08am
Now to answer the original question. You seem to have a good handle on the requirements.
16th Jul, 2011 at 09:33:25am
that one you linked to is most probably a graham russel piston. They where called Evo before at least. Also they are described as having a high silicone content, as are these.
16th Jul, 2011 at 10:16:15am
Any ideas what sort of bhp i could get at say 10psi with the bits i have and as for the T2, what make/madel car could i get one of these from, or is there a different turbo that might suit better.
16th Jul, 2011 at 10:36:22am
On 16th Jul, 2011 wil_h said:
Now to answer the original question. You seem to have a good handle on the requirements. Pistons are the sticking point. I have found that the MiniSpared Mega pistons are very good. But these are NLA, I have not tried the replacement they are now stocking. You could try the Minisport Aus pistons as these are the same as the Megas as I understand it. But they don't make the flat tops ones MS stocked as far as i can tell. http://www.minisport.com.au/category5_1.htm These might be the MS new piston, but it's not clear http://www.minispares.com/Product.aspx?ty=...id=38687&title= I recently bought a new set of these pistons for the next 998T. They are identical to the "Mega" pistons that I fitted in the original 998T nearly 5 years ago. They still use the name "Evolution". I briefly had some +0.120" items from Minisport Aus and they were also the same. All good pistons in my opinion. As for using a 998 instead of a 1275, well, you can enjoy the fun of a turbo without necessarily having to go overboard on gears and clutch. A heavy duty verto clutch and standard gears cope with 100lbft/120hp. I use 214 valves in my 12G295 heads, just for the improved shape and better material. T2 from a Renault 5 GT Turbo is good. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
16th Jul, 2011 at 10:50:39am
would these pistons be ok so,
16th Jul, 2011 at 11:01:17am
Yes the 20950, but these are no longer made by the same firm as the ones I have, but they may be the same spec. I did ask but wasn't 100% on the answer.
16th Jul, 2011 at 11:02:46am
Those are the correct pistons, part no P20950-20.
![]() 4633 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
16th Jul, 2011 at 12:31:32pm
It's well worth swopping out the standard ex valves for the stainless items, the standard ones are monkey metal & usually well worn out.
16th Jul, 2011 at 01:18:43pm
Its actually the other way round in the head i have, the inlet valves seem to be sunk lower than the exhaust valves, but i will probally get unleaded valve seats fitted anyway so should sort out all that, the valves in it were changed at some point i think but dont know if the exhausts are stainless or not, where would the best place to get these be. is there any need fitting bigger valves. A job worth doing is a job worth over doing |
16th Jul, 2011 at 02:18:42pm
It's possible the ex valves may have already been swopped for larger ones then, as I've never ever seen a head where the valves were standard sizes & inlets were sunk more than the ex
Edited by Turbo Phil on 16th Jul, 2011. |
16th Jul, 2011 at 04:40:25pm
i just took them out and measured them roughly with a ruler, the exhausts are 25.5mm and the inlets are 31mm.
16th Jul, 2011 at 05:02:24pm
They're standard valve sizes then. Looking at your pictures the ex look very pitted so by the time they're recut you may need to up the valve size really, or you could fit an unleaded insert & retain the standard size ex. It's hard to make a proper assesment from a picture though .... |
16th Jul, 2011 at 05:13:22pm
ya, i know what you mean, ill see how much fitting the unleaded valves seats in are and go from there, but the bottom line is im better off changing them to stainless ones no matter what size i choose, as for the inlets, will the standard size do or would i be better off going a bit bigger too. A job worth doing is a job worth over doing |
16th Jul, 2011 at 10:23:59pm
17th Jul, 2011 at 09:38:44am
You can get a series 2 escort turbo IC for £15 and some hoses off ebay/scrapyad for a tenner (well I did).
17th Jul, 2011 at 09:58:08am
and MJ is likly pay for itself in fuel economy fairly quickly. On 28th Aug, 2011 Kean said:
![]() 6752 Posts Member #: 828 Post Whore uranus |
17th Jul, 2011 at 11:11:51am
if your on a tight budget then personally i wouldnt even think of a mjlt .
17th Jul, 2011 at 11:53:08am
Trust me. If you run 7psi on a 998 you will be a bit dissapointed, and will want more boost soon. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
17th Jul, 2011 at 12:23:32pm
Wel i have a metro turbo dizzy already but will probally go with a megajolt setup if i can get it cheap enough. the edis bits shouldnt cost a whole pile. And i would rather it run better and more reliable for the extra few euro.
