| Home > 998cc > 998 turbo engine spec help | |||||||
319 Posts Member #: 1742 Senior Member essex |
10th Jul, 2011 at 10:17:40pm
Hiya i am planing on turboing a 998 or maybe a 1098 but not sure if i want such a long stroke. Question one i am planning on using a 12g940 and will open out the chamber as required not a problem i know with the 1275 turbo engines i dee beaked the chambers to stop pre ignition. i was thinking that the block pockets create edges. Will i have problems here with heat i know some use this head.
My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901 |
1391 Posts Member #: 1686 Post Whore Oxford |
10th Jul, 2011 at 10:34:13pm
Surely removing the beak will be detrimental to swirl in the combustion chamber infact possibly leading to pre ignition?.........A 3.44 or a 3.7 should be suitable for a fun boosted road car. But i do like my high reving engines. Possibly a 3.1?
OMG Robert that's a big one |
10th Jul, 2011 at 10:38:57pm
What are you trying to achieve? Are you building from scratch? Why the 1275 head? The sharp edges can cause detonation from the pockets needed in the block. That said if your careful you don't need to pocket the block at all. Just sink the valves slightly into the head so at normal lift the valves clear the deck.
11th Jul, 2011 at 11:55:00am
cheers for your posts. Weather im going to build an engine from scratch or not is what im trying to decide. I have a 1098 engine that i pocketed for the 12g940 head. This is a good engine that i just checked mains on. Or i have 998 that will need full rebuild. I have a few 12g940 heads and a couple of 202 heads to play with but as usual the 202's i have all have shagged exhaust seats so need a fair amount of money thrown there way. I will have a think i got time anyway im fabricating manifolds at the moment. Thanks james My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901 |
11th Jul, 2011 at 09:30:47pm
Stick with the 1098, getting the compression ratio to decent figures shouldnt be a problem with a 940 casting. On 19th Feb, 2011 Miniwilliams said:
