Page: |
Home > 998cc > My plans to 998 turbo | |||||||
9 Posts Member #: 9490 Junior Member |
28th May, 2011 at 09:45:14am
So here is my plans to turbo 998
28th May, 2011 at 09:57:17am
My advise is to spend a few days/evenings reading through this section. There is plenty of information to answer all of your questions.
28th May, 2011 at 10:05:35am
Thanks!
28th May, 2011 at 10:11:04am
Here is the pic.
Edited by faster on 28th May, 2011. |
28th May, 2011 at 10:14:29am
Sorry cant upload pic.......
On 28th May, 2011 faster said:
Here is the pic. I think those are dished pistons? |
107 Posts Member #: 9276 Advanced Member Darlington north east |
28th May, 2011 at 10:51:30am
id also look at not using a std gearbox, have a look at the gt17 turbos and i do believe that someone on here has made taylor made manifolds for them.
28th May, 2011 at 11:03:37am
I dont know what type clutch it is :) It is the original 998 clutch.
On 28th May, 2011 andyuk1275 said:
id also look at not using a std gearbox, have a look at the gt17 turbos and i do believe that someone on here has made taylor made manifolds for them. x-pin diff? as for a clutch is it verto or pre verto? |
28th May, 2011 at 11:38:38am
You don't need a gt17 turbo for 80bhp, you'll want a t2 or gt15 ideally... On 7th Nov, 2011 apbellamy said:
28th May, 2011 at 11:39:53am
verto will have a short arm on the wok, pre-verto have a long arm
On 15th Mar, 2012 wil_h said:
yeah stick the bit in and give it a wobble ![]() |
28th May, 2011 at 12:06:49pm
Main bearings can just be standard replacements,
28th May, 2011 at 12:09:41pm
The clutch is a pre-verto(longer arm)
28th May, 2011 at 12:38:27pm
for the clutch if you want to upgrade an Orange pressure plate will be good.
113 Posts Member #: 9241 Advanced Member Edinburgh / Dumfries |
28th May, 2011 at 12:52:57pm
Turbo k14 is smaller than a garret t3.If i remember right . yes it is - A good little turbo. Running one on another project (not mini) :) |
2nd Jun, 2011 at 08:21:50am
So here is the block and pistons that i have.
Page: |
