Home > A-Series EFI / Injection > Anything I\'ve missed
Ratty
Member #: 9314
Chippenham, Wilts
My MS was originally built for a Ford using edis.
I've added the 4 channel driver board from Jean, added 2 ignition drivers to run coil pack and the 4 injector drivers, removed the unused components from the V3 board.
Tip122 added to drive PWM for idle
Modded the MS2 chip as per Jeans website instructions and added the following for cam sensor
XG1 > SPR1
5v > 1k > Leg 1 U3
I built the jimstim last night, just need to flash the MS2 and connect up the stim to the d15 on the driver board, is this a case of ign out on the d15 to pins 1-6 on the 10 pin header
I would also add a second O2 sensor circuit so that can be logged.
Ratty
Member #: 9314
Chippenham, Wilts
Ah yeh, I'd forgot that bit
I plan to follow the link below but using SPR2 instead of SPR1 as I've used that for the Cam sensor
http://www.diyautotune.com/tech_articles/c...Second_o2_MS2v3
Yes that's right.
Not sure what you mean by this?
Do you mean "ijn out"
If you do, do not forget an earth.
Ratty
Member #: 9314
Chippenham, Wilts
I meant injectors and both coil drivers
I'm not quite sure what you mean by "......and connect up the stim to the d15 on the driver board, is this a case of ign out on the d15 to pins 1-6 on the 10 pin header" ????
If you mean the 10 pin header on the JimStim that connects to the 6 red and 2 bi-coloured LEDs, and the DB15 connector on the 4 channel board, then yes - if you want the leds on the JimStim to flash on ignition events. But bear in mind because you will have modified the MS2 mainboard to take the wasted spark ignition events from LEDs D14 and D16, once you enter the correct settings in the Extra code to enable the coilpack, those two LEDs will flash for ignition anyway.
What you need to bear in mind is that, once you use the 4 channel board and (correctly) remove the existing Injector circuitry from the mainboard, the Injector LEDs will NOT flash on the JimStim so if you want to watch Injection events on the JimStim LEDs you need to connect the relevant pins from the DB15 to the JimStim header.
Otherwise, all I would suggest is to check very carefully how you have wired in the 4 channel board (as it is done in a very different manner for sequential (staged in our case)) and unplug the daughterboard before powering up the JimStim/MS2 and do a voltage check at the 40 pin socket. The instrctions are in the MS3 (three) build manual (it hasn't been added to the MS2 manual yet) but I've read of one person who fried their daughterboard by mis-interpretting the instructions for the 4 channel modification.
EDIT - Paul beat me to it, I type too slowly......
Edited by Rod S on 20th May, 2011.
Ratty
Member #: 9314
Chippenham, Wilts
"If you mean the 10 pin header on the JimStim that connects to the 6 red and 2 bi-coloured LEDs, and the DB15 connector on the 4 channel board, then yes - if you want the leds on the JimStim to flash on ignition events. But bear in mind because you will have modified the MS2 mainboard to take the wasted spark ignition events from LEDs D14 and D16, once you enter the correct settings in the Extra code to enable the coilpack, those two LEDs will flash for ignition anyway."
Excellent
"Otherwise, all I would suggest is to check very carefully how you have wired in the 4 channel board (as it is done in a very different manner for sequential (staged in our case)) and unplug the daughterboard before powering up the JimStim/MS2 and do a voltage check at the 40 pin socket. The instrctions are in the MS3 (three) build manual (it hasn't been added to the MS2 manual yet) but I've read of one person who fried their daughterboard by mis-interpretting the instructions for the 4 channel modification."
I followed these intrustions on Jeans site to connect the 4 channel board
http://www.jbperf.com/sequential/index.html#v3conn
That is the correect set of instructions (there is another set for doing it in non-sequential mode which involves the wires going different places and, if not followed exactly, can end up with 12V on the CPU).
I think the voltage check is well worthwhile though - anything can happen when modifying the boards, like an accidental un-noticed solder bridge onto one of the 12V tracks or pads.
One final point,
When you go to load the code, if the CPU has never had a version of the EXTRA code on it before, it has to be loaded in two stages the first time (fortunately the first time only) involving use of the bootload jumper on the daughterboard.
Once the change to the EXTRA code has been made, future upgrades don't require the jumper.
Ratty
Member #: 9314
Chippenham, Wilts
Do i just use the latest code for ms2?
Sorry for all the questions
No.......
If you are still on standard MS2 code you MUST upgrade to the "Extra" code for all of the siames, sequential, and just about everything else we use.
Here,
http://www.msextra.com/forums/viewtopic.php?f=101&t=39013
As I said earlier, the first time you do this you will need to use the bootload jumper on the daughterboard, the instructions how to do this are put on-screen by the .bat file, but follow them carefully.
Ratty
Member #: 9314
Chippenham, Wilts
Sorry I meant the latest extra code, trying to type too quickly with the boss nearby :)
Thanks for all the help
Edited by Ratty on 20th May, 2011.
Then it's up to you - I'm still on a 3.0.something, I haven't bothered going to 3.1.0.
If you are 3.anything personally I would check everything else works before upgrading.
The other thing, if you weren't already aware, you will need TunerStudio or MegaTunix to access the complete menus for siamese/sequential - the original Megatune cannot handle the extended menus.
You will also need to connect OptoOut to JS10.
Ratty
Member #: 9314
Chippenham, Wilts
Got that, missed it on first post
Ratty
Member #: 9314
Chippenham, Wilts
Well it works, 4 flashing injector lights, 2 coil lights, just need a engine to test it on now :)
Ratty
Member #: 9314
Chippenham, Wilts
Can I confirm if the ground for the second O2 circuit goes to proto ground
Yes, use the proto area ground.
Ratty
Member #: 9314
Chippenham, Wilts
Cheers, ecu now finished, all sensors are here and tested to be working.
A spare 850 engine has fired up on a carb.
Mpi manifold has arrived so providing the Mrs let me play this weekend I might get the chance to test it all out :)
