Home > 998cc > T2, what\'s what, cracks, studs & fitting..
analogue_radio
Member #: 4600
Melton Mowbray,
near Leicester
Right! another bombard of questions, and I've already done a search on these things.
A) Are these cracks okay?
B) Why won't it fit?
Do I need to undo something and reposition it so it faces upwards like so..
Also what's been welded in the photo below, I notice the actuator has been taken off as well?
C) What are the correct studs to mate the T2 with the down pipe? (It's a mirage job)
D) Gasket, will paste do? or shall I cut my own out of some gasket material?
CHEERS!
If anyone has PDFs or documents with diagrams drop me a message.
jamie@thefatgarage
Member #: 9345
Sheffield
A. Probably ok. Loads of t2's have cracks there. Not using the wastegate (the welded up bit) on the turbo makes it less important. Yours is set up to use an external one off the exhaust manifold.
B. Loosen the bolts and rotate the centre relative to the exhaust bit.
C. M8 usually I think but yours seem to have been helicoiled to something or other... they can be f##kers to drill out after years of heating etc.
D. Metal gasket, off ebay. You can't use normal gasket material.
miniminor63
Member #: 672
The oversills police
Oslo, Norway
The one with the external wastegate was just an example picture. The wastegate is what has been welded shut as he is using an external one.
turbominij
Member #: 2104
Essex - UK
should be ok my t2 was cracked and i didnt have any issues even boost was stable using an electronic boost controller.
"Tuning should be a compromise between what is possible and what is necessary"
10)Thou shalt always quest for more power
dan187
Member #: 6724
Wootton Bassett
yeah you need to loosen the circlip to rotate the centre section so the water pipes face the correct way. look up thread on here about need for water cooling.
my cracks were worse and is running fine.
My T2 came with studs
as said, metal gasket needed, i got mine off ebay
1275 EFi Turbo
turbominij
Member #: 2104
Essex - UK
rich at mirrage motorsport is a good place for gaskits and he will be able to do the studs
pair of gaskits is £10
he also does the tiny k'nuts that help fittment
The centre section on the T-series Garretts is not secured with a circlip, you need to undo the bolts around the 'snail' flanges.
Any suitable M8 stud will be suitable. I like to use stainless if available, but I have a mix of mild and stainless.
Also, if the exhaust flange is nice and flat you can get away without a gasket, I never used on on my T2.
analogue_radio
Member #: 4600
Melton Mowbray,
near Leicester
Cheers lads you are all stars.
Dan187 you mentioned the bit fouling is the water outlet or inlet. Is watercooling needed? I didn't think it was.
& cheers for the gasket (I didn't think about it being an exhaust and using a paper gasket, duh) stud and crack advice! All brilliant.
Thanks again.
Some people use watercooling, some dont. The way i think of it is that its there for a reason, they wouldnt have put it there for a laugh. Im definately going to plumb mine in for the effort it takes to do it, even if nothing comes of it.
dan187
Member #: 6724
Wootton Bassett
like i say there was a thread a few weeks ago which higlited it and linked to a page explaining the importance and showed how to plumb it in correctly. You need it to self pump the water when the engine is off
1275 EFi Turbo
analogue_radio
Member #: 4600
Melton Mowbray,
near Leicester
Yeah makes sense, now is the time to plumb it in.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=418473
And the oil outlet feeds back into where the mechanical pump was on the back of the block, this then dumps the oil back in the gearbox ready for another cycle?
I'll get the T2 fitted properly first and then ask questions about what's feeding to and from where *happy*
analogue_radio
Member #: 4600
Melton Mowbray,
near Leicester
How the hell is it supposed to rotate? I've undone the 4 bolts and removed those, under the 4 bolts were two metal plates which have also been taken off.
I understand it's threaded? so it's just a case of undoing it and rotating and then replacing the plates and bolting it back up?
Well the sodding thing doesn't move, i've given it elbow grease, had it in the vice, applied heat.. nothing.
Am I missing something?
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=5742 might help :)
analogue_radio
Member #: 4600
Melton Mowbray,
near Leicester
Lovely! that didn't come up when I searched *tongue*
