| Home > Show Us Yours! > My side mount manifold | |||||||
27th Apr, 2011 at 12:29:45am
Well title says it all just intrested in some feed back pos or neg I am trying to run all 3 ports into a collector at the turbo flange so far so good I think!
On 17th Feb, 2009 Rob H said:
![]() 6752 Posts Member #: 828 Post Whore uranus |
27th Apr, 2011 at 12:31:13am
nice job paul.
27th Apr, 2011 at 12:47:47am
Nice work mate. I have started posting on Instagram also my name on there is turbomk1golf
1391 Posts Member #: 1686 Post Whore Oxford |
27th Apr, 2011 at 02:05:57am
Thats pretty good going. I would like to say something about the length from outer ports to turbo flange in comparison to the centre port.
OMG Robert that's a big one |
27th Apr, 2011 at 08:37:27am
I see what you are saying Sam,
27th Apr, 2011 at 09:50:41am
You did say negative feedback was OK :)
27th Apr, 2011 at 09:53:24am
Sorry to hi jack this thread, but what are you peeps thoughts on bore size? Ive used 1" nominal bore pipe.. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
27th Apr, 2011 at 10:05:09am
Mike, 1" nominal bore pipe is actually about 28mm ID.
Edited by Paul S on 27th Apr, 2011. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
27th Apr, 2011 at 10:05:20am
Yup deffently want PRos and cons, I see what you are saying Paul and it is a consern but ! I unsure as to whether the VE gains are going to be worth anything considering you would have to turn no4 primary back on it's self to make it even close to the right length,
27th Apr, 2011 at 10:11:22am
I'm using 33 od which is 31.5 I'd which seems prfect to me it squares out niclely at the port. The bends are made in 38 od as the mandrel bender I have acess to slightly deforms the pipe into a more oval shape so I steped up a bit to keep every thing nice and smoth. On 17th Feb, 2009 Rob H said:
27th Apr, 2011 at 10:16:54am
Well, all my investigation shows that you can gain as much of a performance increase from an equal length turbo manifold as you can from fitting a 7 port head.
27th Apr, 2011 at 10:20:19am
Paul i managed to get the lengths right without much hassle.
27th Apr, 2011 at 10:22:10am
Mr s 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
27th Apr, 2011 at 10:36:05am
On 27th Apr, 2011 Paul S said:
Well, all my investigation shows that you can gain as much of a performance increase from an equal length turbo manifold as you can from fitting a 7 port head. So I think it is worth getting it right. And if you already have a 7-port head it make the design of a manifold much easier as you don't have to worry about the inlets. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
27th Apr, 2011 at 10:59:30am
I was thinking about this Wil. You could make a banana style manifold but keep it down the back of the engine on the 7-port. If something is worth doing, it's worth doing half of. |
27th Apr, 2011 at 11:29:16am
You can indeed john, I have been looking into it and it shouldn't be too difficult. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
27th Apr, 2011 at 11:36:10am
heres a rough sketch to illustrate 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
27th Apr, 2011 at 11:57:02am
Nana's are wrong way up Mike If something is worth doing, it's worth doing half of. |
27th Apr, 2011 at 11:59:14am
Shit.......Im not well 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
thats a fair claim. Hope its true ha!
