Page: |
Home > A-Series EFI / Injection > A few final Installation questions for Injection system | |||||||
96 Posts Member #: 7325 Advanced Member |
21st Apr, 2011 at 09:17:49pm
Hi Im just about finished the build of my Canems injected 1380. I have a few questions abot the fuel lines.
21st Apr, 2011 at 09:43:09pm
In order:
11046 Posts Member #: 965 Post Whore Preston On The Brook |
21st Apr, 2011 at 10:54:15pm
Is this a standard MPi injection manifold? On 26th Oct, 2004 TurboDave16v said:
21st Apr, 2011 at 11:01:10pm
Nope its a custom inlet with twin 34 mm Throttle bodies :), they are very short theres about 10cm from valve to the injector, the manifold is only 4 or 5cm long. Edited by ciaran on 21st Apr, 2011. |
21st Apr, 2011 at 11:16:13pm
On 21st Apr, 2011 Paul S said:
In order: The outlet from the fuel presure regulator is the return to the tank. 1. Best get some clips if you can, however, the rail should hold the injectors in place. 2. Fuel goes in one end of the rail, through the regulator at the other end and then back to tank. You should also connect up the vacuum reference signal on the regulator. 3. Not sure about minispares inertia switch, but usually wired in the positive feed to the pump. 4. Servo does not actually do much. Either remove servo and fit yellow tag master cylinder or get some pressure tappings into the inlet manifold runners. 5. Best place is downstream of the throttle in the runner, otherwise as close top the inlets as possible. 6. best use P clips and 10mm OD copper. 7. Alternatively leave standard sensor in head and drill a thermostat sandwich plate for new sensor. Water gets hot each side of the thermostat even when there is no flow. 8. Yes. Thanks so much for answering it all :) |
Page: |
