Page: |
Home > MS Code Discussions > MS code error? | |||||||
77 Posts Member #: 7659 Advanced Member Netherlands |
3rd Apr, 2011 at 12:50:24am
I am using the fast idle output port to regulate my electric fan. I have set the idle control algorithm to none. In the extended menu I have set the PM2 port to switch to 1 when coolant temp > 88C.
3rd Apr, 2011 at 01:11:52am
There is no msq attached. You should also post a log of this. And posting on the msextra forum may be the best way to get more responses.
3rd Apr, 2011 at 09:23:33am
Sorry forgot to attach the MSQ file. here it is. I wil make a log also later today and shall also post this on the MSextra forum.
3rd Apr, 2011 at 10:11:24am
My guess is that it is something to do with the fan dragging the volts down and affecting the injectors.
3rd Apr, 2011 at 10:43:02am
Thought of that also but did not check it the strange thing is that it only first occurs after the fan switches of again. Also the higher voltage with the fan of should make it run richer instead of leaner. Will do some measurments and post a log. |
3rd Apr, 2011 at 10:59:20am
Your VE table is a little hilly in the idle region.
3rd Apr, 2011 at 12:18:59pm
I agree with Paul.
3rd Apr, 2011 at 12:56:40pm
Thanks for your respons.
3rd Apr, 2011 at 03:53:56pm
On that log you have a very high idle speed. As you say, about 1500RPM.
3rd Apr, 2011 at 03:58:44pm
Right, I'll go back to my original theory.
3rd Apr, 2011 at 04:06:54pm
Resistor R6 was 12 instead of 10K just changed and and wil give it a new try.
3rd Apr, 2011 at 04:11:07pm
Too much battery voltage compensation combined with a wrong opening time and large injectors will have a massive fueling impact at idle.
3rd Apr, 2011 at 04:41:50pm
On 3rd Apr, 2011 gemertw said:
Its correct that I still have the default settings in the acceleratiopn wizzard. as I only was trying to get a good idle at this moment. I will read thru the thread on this subject before trying again. What I think may be happening (as you go rich when the fan runs) is the fan is generating electrical "noise" on the TPS signal. In my case it was a battery charger generating the noise (my battery was dead so I was running a charger on it constantly). The default settings in accelleration wizard are far too high for siamese pulse widths so a small amount of noise added to the TPS signal is seen as an increase in TPS rate of change (%/sec) so adds injector pulsewidth and you go richer. I would try turning TPS AE off (turn the TPS vs MAP box from 100% to 0%) and try again - you will probably have to reset req'd fuel to get a suitable pulsewidth back as the AE addition from the wizard will be gone - and if the fan no longer has an effect, try the settings Paul suggests in the other thread. Schrödinger's cat - so which one am I ??? |
3rd Apr, 2011 at 05:45:00pm
I don't think tht the problem is AE in this case. if you look at the log, at no time do the Accel or Deccel indicators light up.
3rd Apr, 2011 at 06:00:09pm
Decreasing the voltage correction to half the original value seem to have cured the problem decreasing it further resulted in running a bit richer when the fan turned on. So I am a little step further now. Pulse width at idle is now around 1 msec I to aprox what values should I set the acceleration wizard? |
3rd Apr, 2011 at 06:11:52pm
Are you still running without the vacuum referenced fuel presure regulator?
Edited by Paul S on 3rd Apr, 2011. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
3rd Apr, 2011 at 06:19:49pm
Yes I am still running without vacuum control on the fuel presure regulator. I wil by one next week. Just changed the injector opening time to 0.75msec this improved the controlability at idle. Wil try to change it a bit more to see what happens is has a big impact on the ve table values. I am running low z injectors from delphi do you perhaps now at what the correct parameters for these are? |
Page: |
