Home > 998cc > actuator
softlad1988
Member #: 8462
which is the best actuator to use on a t2 turbo on a 998?
Rick.SPI
Member #: 8027
the normal t2 actuator. then a bleed valve to whatever boost your aiming for. :)
softlad1988
Member #: 8462
what does the standard t2 one open at?
Depends what car its from.
jimmy
Member #: 829
essex
R5 turbo had two pipes to the actuator
1293 Turbo mini
I "think" 10psi
dan187
Member #: 6724
Wootton Bassett
On 15th May, 2011 John said:
I "think" 10psi
The R5 one i got was 10psi
1275 EFi Turbo
softlad1988
Member #: 8462
is there any way that i could run 7 psi using this actuator?
No.
