Page: |
Home > A-Series EFI / Injection > megasquirt tuning cable | |||||||
40 Posts Member #: 8907 Member |
10th Feb, 2011 at 07:54:11pm
Hi all what db9 to usb serial cable have you found to work and where would you recommend to get one from thanks ms2 is beyond me come back carbs all is forgiven why did I decide to modify a spi mini to late to turn back now so please put up with my stupid question and humour me |
3329 Posts Member #: 184 Senior Member Melton Mowbray, Pie Country |
10th Feb, 2011 at 08:16:23pm
You need a straight through cable as described in the megamanual
http://www.twin-turbo.co.uk
774 Posts Member #: 6724 Post Whore Wootton Bassett |
10th Feb, 2011 at 08:36:32pm
Get this, nice and long, well cheap and worked a treat for me. You need to google "usb serial driver prolific" and download one because the one that comes with the cable doesn't work
10th Feb, 2011 at 08:41:01pm
somthing like this
11046 Posts Member #: 965 Post Whore Preston On The Brook |
10th Feb, 2011 at 10:26:27pm
I have been considering the FTDI based adapter over the Profilfic based, since the Prolific appear to be a bit hit and miss.
11th Feb, 2011 at 12:43:40am
On 10th Feb, 2011 dan187 said:
Get this, nice and long, well cheap and worked a treat for me. You need to google "usb serial driver prolific" and download one because the one that comes with the cable doesn't work http://cgi.ebay.co.uk/USB-2-0-RS232-SERIAL...=item35afe48ac8 will give that a go for £2 lol witch one you donloaded of google as 1000's or will any do ? ms2 is beyond me come back carbs all is forgiven why did I decide to modify a spi mini to late to turn back now so please put up with my stupid question and humour me |
11th Feb, 2011 at 08:28:49am
Can't remember but have found the installer on my pc
1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
18th Mar, 2011 at 08:27:14pm
On my old Dell laptop, I've used the Prolific 9 pin to USB convertor and had no problem with the original Prolific driver straight out of the box. Worked a treat but I did have to cut the metal shroud off the 9 pin end of the cable as there were earth problems which lead to issues to begin with. Once sorted it works fine on the old Dell.
Page: |
