Page: |
Home > A-Series EFI / Injection > MS Build Guide - Abbreviated | |||||||
![]() 8604 Posts Member #: 573 Formerly Axel Podland |
9th Feb, 2011 at 04:35:11pm
This is a cut down version of the build guide to just give a taster of what is involved.
9th Feb, 2011 at 05:09:01pm
As an EFI novice, I've read it and it all makes good clear sense to me. On 11th Feb, 2015 robert said:
i tried putting soap on it , and heating it to brown , then slathered my new lube on it ![]() |
9th Feb, 2011 at 05:28:10pm
Thank you, Andy.
9th Feb, 2011 at 05:30:35pm
One comment about the link for the wiring. You should use the msextra manual instead:http://www.msextra.com/doc/general/ms2external.html
Edited by jbelanger on 9th Feb, 2011. |
9th Feb, 2011 at 05:33:56pm
Thanks Jean, link updated. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
9th Feb, 2011 at 06:04:27pm
On 9th Feb, 2011 Paul S said:
Thank you, Andy. Hopefully it will help dispel some of the myths about the complexity and difficulties of port injection and 5 Port heads. No prob's. However I don't think the difficulties are assembling the hardware and electronics (although my soldering is poor at best!). For me, the tuning would be the difficult bit. On 11th Feb, 2015 robert said:
9th Feb, 2011 at 06:36:43pm
On 9th Feb, 2011 apbellamy said:
For me, the tuning would be the difficult bit. True, you do need average intelligence for that ![]() Edited by Paul S on 9th Feb, 2011. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
9th Feb, 2011 at 06:40:34pm
9th Feb, 2011 at 06:47:53pm
Seriously, the only additional tuning to normal EFi is the injection timing table.
![]() 5988 Posts Member #: 2024 Formally Retired Rural Suffolk |
10th Feb, 2011 at 07:35:32pm
For the "full" version (or however Paul and I decide to take it forwards) I'm writing up how to turn this
10th Feb, 2011 at 07:42:08pm
Forgot to say excellent guide chaps! Well
![]() 6748 Posts Member #: 828 Post Whore uranus |
11th Feb, 2011 at 09:02:32am
On 10th Feb, 2011 Rod S said:
For the "full" version (or however Paul and I decide to take it forwards) I'm writing up how to turn this ![]() ....very small number of parts, along with two small boards from Jean (not yet in the photo as they are only just being posted from Canada).... into a fully sequential 4 channel EMS that can run the siamese code for a basic 2 channel siamese setup or 4 channel (staged siamese) injection or plain 4 channel sequential for those using 7/8 port heads. So long as you can solder, it is a very cost effective way forward. I'll build it with photos over 10-14 days - not because it takes that long, probably only 3-4 hours - but because I want to photo and document as I do it and I need to wait for the two additional boards from Jean. Once finished and tested I'll put it up for sale in either 2 or 4 channel form and low or high z injector form - my next version will be a little more advanced than this but this version will be at least the equivilant of what myself, Paul and Graham are working with at the moment. very exciting . well done . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
11th Feb, 2011 at 09:13:54am
got to say this subject, although of interest, has always been over my head, but having read through the manual, it appears relatively straight forward now - all more than likely down to Paul, Rod and Jean's constant hard work on the subject to make it that bit more understandable for the rest of us.
11th Feb, 2011 at 10:27:45pm
From the photo above, after about 3 hours it became this...
12th Feb, 2011 at 09:58:53am
so economically speaking rod , one would buy the bare board from america ,then get the components your showing in england ,and the little boards from jean ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
12th Feb, 2011 at 11:05:04am
Robert, personally I would say yes, particularly in this new configuration which uses so few of the standard parts (I'll explain why it uses so few later).
12th Feb, 2011 at 03:57:21pm
i see . thats very generous in time and effort of you rod . if i can get to a position , with my multiplicity of projects,
21st Feb, 2011 at 08:20:50pm
All boards now received (postage from Canada is really quick).... I just need a few parts from Farnell (UK) to be complete.
22nd Feb, 2011 at 08:03:39pm
Farnell Belgium - 1
13th Mar, 2011 at 07:48:17am
rod , i didnt see this had progressed , a few more infantile questions :),
13th Mar, 2011 at 03:25:18pm
Robert,
Edited by Rod S on 13th Mar, 2011. Schrödinger's cat - so which one am I ??? |
13th Mar, 2011 at 07:15:09pm
thanks rod ,this looks very encouraging for those on a budget. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
Page: |
