Page: |
Home > A-Series EFI / Injection > Flow Rate of Stage 3 cylinder head? | |||||||
96 Posts Member #: 7325 Advanced Member |
26th Jan, 2011 at 02:11:06pm
Im doing my theses on fuel Injection and at the moment Im working out the CFM or Litres/min or air flow so I can size the throttle bodies for the System.
1596 Posts Member #: 8027 Post Whore Thrapston, Kettering, Northants NN14 |
26th Jan, 2011 at 02:19:35pm
stage 3 dosnt mean alot without its exact specs mate its just a term for companys to sell a head. all can be different and not one will flow the same as another... well not exactly. On 17th Feb, 2011 apbellamy said:
I popped my first one out the other day... |
26th Jan, 2011 at 02:22:31pm
Right ill go out and measure the Area of the inlets. and have a look at the valves |
3329 Posts Member #: 184 Senior Member Melton Mowbray, Pie Country |
26th Jan, 2011 at 03:16:28pm
Nobody really quotes CFM figures for their heads, if you want that you will have to measure it yourself i would guess. Can be done with a vacuum cleaner and a manometer. http://www.twin-turbo.co.uk
26th Jan, 2011 at 03:21:28pm
I had a quick measure and worked the CC or Cm3 of the Intel ports to be 83.5 cm3.
26th Jan, 2011 at 03:23:24pm
Humm i need a manometer? Ill get onto my supervisor and ask if I can get hold of one.
26th Jan, 2011 at 03:34:00pm
Get hold of a copy of Vizards book. it has many flow curves for different cylinder head modifications.
26th Jan, 2011 at 03:42:29pm
I have vizards book, I was looking through it, but it doesnt have a CFM for my exact head. Would using the theoretical CFM be adequate for sizing the TB? although the figures do seem a little optimistic, but looking at the CFM for other larger CC engines they seem to be accurate.
26th Jan, 2011 at 04:02:05pm
Quoted CFM values for heads is just for comparison purposes. They are based on a given pressure drop. I've seen 2.5", 10" and 25" H2O quoted in the last few days alone.
26th Jan, 2011 at 04:05:59pm
Thanks man, Ill go work that out. |
Page: |
