Home > Carls Guessing Games > not a geussing game but an idea!
with forceracing having growing number of products does this mean there maybe a range of light weight exhasts? maybe some bolt on manifolds for the new K head kits?? no company does turbo manifolds why not start something off?
the ideas
Ti exhaust boxes
turbo inlet manifold
turbo exhaust manifold
ti/alloy dry deck kits for Khead/Kad 16v
steel tubular subframes for abit less than the TI one
Alloy rear arms
tubular steel top arms for coiovers and cones
front subframe brace bars
Alloy rear beams
appoligies if this is in the wrong place or should have been pm'd
paul
anyone can have anything made.
But you do realise how much custom titanium parts like an exhaust would cost ??
Here is one example...maybe it could be adapted to fit an old mini lol
http://www.titaniumperformance.co.uk/produ...-exhaust-system
Its just an idea, im not saying do it just cause i said it would be cool i was bouncing thoughts idk could be good little helper sort of thing people posting ideas, as it seems carl can do more ti and alu parts now the force catalog could grow not just force racing anyone really it is a comunity afterall
the ideas
Ti exhaust boxes
Alloy rear arms
Alloy rear beams
paul
Exhaust boxes in Ti wouild be a pain to make and very expensive to produce due to welding costs,
the Don uses 1mm thin wall stainless pipe and carbon cans .
Inlet and exhaust for turbo K heads are on the cards,
so are dry deck ports
i once made a steel tubular subframe for a K series and it was heavier than a standard mini frame due to the amount of tube i put in it, it was head and shoulders above any of the other frames available for quality if i do say so myself, fully tig welded,
i heve been asked before but still lots of work/ expensive involved, .
billet rear amrs are in the thinking about phase, just mullnig stiff over in my head,
ive tried to resist gonig down the steel component route,
alloy rear beams i don't like the sound of,
carl
I think there's a market for billet rear arms for rubber cone suspension - I appreciate that the bit for the knuckle would be a PITA and increase cost quite a bit.
you cover the development costs of the first pair inc
design,
programing,
jigs .
fixtures,
material .
, and i'll machine them for nowt,
wez
Member #: 9271
Stoke on Trent
design,
programing,
jigs .
fixtures,
material .
what sort of mc's do you use?? only asking because im a turner and use cnc myself.
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
I'll knock it all up myself and drop it in at the end of the week *wink*
Don't go sniffing or licking the tail of your crank when you finally pick it up *wink*
Why? What have you been doing to my crank tail? I hope you haven't inserted it in an unsavoury places... *wink*
