Home > Wanted > SINGLE cast +.020 OMEGA piston, gudgeon pin (and rings ?).
turbominivanman
Member #: 1504
Westbury, Wiltshire
Hi guys.
I have three used +.020 cast Omegas (1293cc) with 8 cc dishes and new rings.
I'm after a fourth piston, either new or used, to make up a set of 4.
If you have a single cast OMEGA OP120 piston (& pin) with good ring lands and preferably with minimal wear (similar to the two pics attached), could you PM me please.
Any dish cc considered.
To make up the full set of new rings I have for these pistons I'm also after a new 2nd compression ring if you have one as one is missing from my set.
Many thanks.
Richard.
Aren't Omegas either 6cc or 10cc?I've never seen 8cc ones, or is that what you've modified yours to?
Just for clarification :)
turbominivanman
Member #: 1504
Westbury, Wiltshire
Yes V,
6cc originally then modified to 8cc.
BUT, I dont mind if someone has a 6cc, 10cc or bigger.
Richard.
I do have one.but unsure wether its forged or cast,it has a little bit of damage to the crown,msy be no good
turbominivanman
Member #: 1504
Westbury, Wiltshire
Can you post up a pic and get the casting number from the inside wall of the piston for me please Rubes.
If the lands are ok and the crown can be salvaged by taking the bowl cc out a little then it could be just the ticket.
Cheers.
Richard.
scott6058
Member #: 2392
Silly Me
Have you had luck with locating op120's?
I have a new full set and was wondering if they suit street use.
I have heard the rings could be inferior.
Your opinion is very valuable.
Best regards Scott
