Page: |
Home > A-Series EFI / Injection > JimStim Modifications | |||||||
186 Posts Member #: 7637 Advanced Member Fremont California |
16th Dec, 2010 at 06:07:14pm
I read either in the forum or on a vendor page that there are modifications required to the JimStim if running some of the addon boards.
16th Dec, 2010 at 06:17:01pm
There is no need to modify the JimStim for the 4-channel driver board but if you want to see the outputs on the JimStim LEDs, you'll need to run wires from the 4-channel board output to the JimStim LED header.
17th Dec, 2010 at 01:00:13am
Thanks Jean.
17th Dec, 2010 at 10:25:59am
We put the DB15 above the LED location. We then fitted the LEDs on the other side of the board and drilled new holes. We will seal the original holes.
Edited by Paul S on 17th Dec, 2010. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
17th Dec, 2010 at 03:52:13pm
Thanks Paul. That was my next question to you as I thought I remembered a thread where you had assembly photos.
17th Dec, 2010 at 07:28:26pm
In that thread(Sequential Megasquirt) this is mentioned:
17th Dec, 2010 at 07:53:29pm
This forum - Gerald O - with a space.
17th Dec, 2010 at 09:37:40pm
Thanks again
Edited by tmsmini on 18th Dec, 2010. |
Page: |
