Page: |
Home > A-Series EFI / Injection > JB Performance I/O Extender & Logger | |||||||
13th Dec, 2010 at 05:47:41pm
We are going to equip the 998Ti with loads of instrumentation to gain a better understanding of turbo & intercooler performance.
13th Dec, 2010 at 06:02:47pm
nice,
13th Dec, 2010 at 07:23:31pm
I've got the I/O x board (not yet fully assembled but that's the story of my life....) and what Jean has done is certainly taking things forward, it's just a shame the rest of my build (the actual Mini) is so far behind the fuel injection and electronics I've been working on.........
13th Dec, 2010 at 07:25:21pm
So is this a true stand-alone logger? Or does it have to work with / through MS?
13th Dec, 2010 at 07:53:01pm
ah!,
13th Dec, 2010 at 07:56:50pm
On 13th Dec, 2010 TurboDave said:
So is this a true stand-alone logger? Or does it have to work with / through MS? That is totally not obvious anywhere in the link? A little bit of reading would answer that. Or lock the thread instead ??? Schrödinger's cat - so which one am I ??? |
13th Dec, 2010 at 08:04:31pm
On 13th Dec, 2010 Joe C said:
hum, i'm going to have to see if it is possible to get it in a case with the MS now... Joe, before this thread gets locked or deleted, Jean's newer boards are 100mm. The rather antiquated MegaSquirt cases are 4" (101.6mm). Everything in the developed world is now 100mm (Eurocard is 100x160) so you can put the 100mm ones (very loosely) into a MS box but you can't put the MS boards into a standard 100mm box. No offence intended to the MegaSquirt community but your choice of retaining a 4" profile is history :) Schrödinger's cat - so which one am I ??? |
Site Admin 15300 Posts Member #: 337 Fearless Tom Fenton, Avon Park 2007 & 2008 class D winner & TM legend. |
13th Dec, 2010 at 08:09:16pm
Rod, give over with the attitude, TM has always been and will always be a place open to all kinds of debate.
13th Dec, 2010 at 08:57:40pm
So is this a true stand-alone logger? Or does it have to work with / through MS? That is totally not obvious anywhere in the link? The information on the web page is not complete and somewhat out of date. I need to expand on it and correct a few things. There is a lot more information on my forum. The intent is to be able to have this as either a standalone data logger and as an extension to an MS2/Extra or MS3 ECU. At the moment the standalone part is missing some code to use the SD card so it would require using a laptop to record the data but it can be done without being connected to an MS ECU. Jean |
14th Dec, 2010 at 01:00:53pm
Jean,
Edited by TurboDave16V on 14th Dec, 2010. On 17th Nov, 2014 Tom Fenton said:
11046 Posts Member #: 965 Post Whore Preston On The Brook |
17th Dec, 2010 at 03:04:23pm
I like this idea too, especially if it is a stand alone product On 26th Oct, 2004 TurboDave16v said:
10020 Posts Member #: 1456 Mongo Barnsley, South Flatcapshire |
17th Dec, 2010 at 03:14:16pm
Yep looks pretty good to me. Plenty of inputs. If something is worth doing, it's worth doing half of. |
17th Dec, 2010 at 03:15:16pm
Have you considered a 3rd Wideband downstream of the turbo Paul? If so any reason for not including one apart from cost? If something is worth doing, it's worth doing half of. |
17th Dec, 2010 at 04:46:14pm
On 17th Dec, 2010 John said:
Have you considered a 3rd Wideband downstream of the turbo Paul? If so any reason for not including one apart from cost? Yes John, it is actually on the second diagram. It is a bit of an expense when you already have two. Might be good to use to autotune the VE map though. Then just use the main two to set the injection timing. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
17th Dec, 2010 at 04:49:23pm
Aha I see it now If something is worth doing, it's worth doing half of. |
13th Jun, 2011 at 05:39:37pm
Finally got around to putting this together.
4625 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
13th Dec, 2018 at 01:23:47pm
Did you get any further with this Paul ?
13th Dec, 2018 at 02:07:39pm
I'm afraid not. It was abandoned along with the ex-Miglia project.
Page: |
