Home > A-Series EFI / Injection > AT Throttle Body
Following that thread last week, I thought I would investigate the AT Power throttle bodies.
Same 50mm bore as the Ford jobbie pictured that I usually use but much more compact.
Available from:
http://atpowershop.co.uk/catalog/50mm-sing...-body-p-93.html
Looks pretty nifty Paul. Shaftless too *smiley*
beautiful :)
manifold
Member #: 1734
Lancaster
nice stainless linkage on them too.
I don't think they were AT ones but JonhK showed me a set of four on one of SC's demo 8 port engines with the shaftless linkages at their place in Norfolk earlier this year.
They were much smaller (being four of them on an 8 port) and VERY compact.
IIRC he said the shaftless linkage across all four allowed the use of a smaller (nominal) body which improved low down torque.
Obviously 4 injectors and no siamese issues.
I think the thing with factory ones - I've got a Rover one and it is massive - is they have all sorts of tappings, heater conections, bulky IACVs, massive TPS sender, all because there is plenty of room under a modern car bonnet.....
Actually, the fact that it is so small is the only positive aspect.
The fixings holes are only 5mm diameter. The idle stop is in the wrong position and the WOT stop lets it go over centre.
Also not sure that you can get a 50mm silicone pipe and clamp on the inlet without it fouling the quadrant.
Still if SC use them, they must be good.
Quite tidy looking. But is the pipe 50mm, or butterfly ?
Having big TB's on a boosted engine isnt great for driveability, and they really arent needed for power.
i recently bought a 54mm jenvey thats a nice tidy TB
Whoops. By PM.
On 6th Dec, 2010 johnK said:
well well can't help ourselves cay we - try doing something original Paul - I don't know what your beef is but your dozy attitude has been noted by lots of people on here - if you don't wish to get yourself ousted I suggest you keep thoughts to yourself
and if you can do better - PROVE IT!!!!!!!!!
Edited by Paul S on 6th Dec, 2010.
I've just ordered a couple of 35mm Jenveys for the Racing Flame. Be good to make a comparison.
John has since told me the ones I saw are made by AT but designed by both parties jointly but marketed under the SC name. I hope I got that right.... I don't want to start another fight.
The four together are obviously for a completely different application to those of us persuing injection and turbo on a 5 port, but they still looked really neat and compact in a row of four.
bhpmini
Member #: 8907
so is that a at on the new sc 5 port kit? http://www.youtube.com/user/specialistcomp...u/0/DzU9QBAr1kc
looks good but think a ms and jenvey tb will do the same job for less
Edited by bhpmini on 25th Dec, 2010.
ms2 is beyond me come back carbs all is forgiven why did I decide to modify a spi mini *frown* to late to turn back now so please put up with my stupid question and humour me
fab
Member #: 100
Parisien Turbo Expert
Paris\' suburb
Good luck with that.
bhpmini
Member #: 8907
Don't need good luck as I am not doing a set up like that was just wondering if it was a SC or AT throttle body
Ozyris
Member #: 9054
Disneyland Near Paris
i have receive mine from the SC turbo kit
i will tell you my impression in condition =)
