| Home > 998cc > Spare 998 plans | |||||||
347 Posts Member #: 9075 Senior Member Peterborough |
20th Nov, 2010 at 08:30:59pm
So I have a 998 in my garage that I have taken out of my project, the car is going 1293 turbo so the engine is going spare.
1391 Posts Member #: 1686 Post Whore Oxford |
21st Nov, 2010 at 12:52:55am
Pocket the block and plonk on a 940 casting head.
OMG Robert that's a big one |
21st Nov, 2010 at 11:05:10am
I thought about different heads and cams but how much would pocketing and a head cost?
21st Nov, 2010 at 12:03:14pm
Have a look at the you tube link in Robert's signature. There is a video of him pocketing a block. doesn't look difficult. On 11th Feb, 2015 robert said:
21st Nov, 2010 at 12:15:46pm
na mg metro cam works well in a 998 |
21st Nov, 2010 at 03:50:30pm
You're right actually, doesn't look too difficult at all.
On 21st Nov, 2010 apbellamy said:
Have a look at the you tube link in Robert's signature. There is a video of him pocketing a block. doesn't look difficult. Edited by DaveVader on 21st Nov, 2010. |
![]() 1137 Posts Member #: 1450 Post Whore Near Paris - France |
21st Nov, 2010 at 07:13:22pm
12G202 + some head work and a skim + a cam (260ish) and a stage 1.
Rusty by nature
They said "That sounds rough mate." I said "Cheers it cost me a fortune to make it sound like that!" |
21st Nov, 2010 at 07:19:45pm
get one of these,
21st Nov, 2010 at 07:27:52pm
just stick some nitrous on it? "Turbo's make torque, and torque makes fun"
21st Nov, 2010 at 07:28:19pm
hmm, I fucking love bananas!
On 21st Nov, 2010 Joe C said:
get one of these, http://cgi.ebay.co.uk/NEW-CHALLENGE-1200W-...=item3a5cee24c3 then make some shelves after... Edited by DaveVader on 21st Nov, 2010. |
23rd Nov, 2010 at 11:27:28pm
So far I have decided...
115 Posts Member #: 2830 Advanced Member Costa del Northern Ireland :) |
24th Nov, 2010 at 04:42:17am
Before I went turbo my 998 had an mg 12g940 Swiftune sw5 cam cooper freeflow manifold Maniflow exhaust electronic dizzy and standard 1 1/2 su and airbox with a k&n reacement filter. 73 bhp on the rollin road but the rest of the Motor was tip top aswell fully rebuilt. Fully ballanced with centre main strap and arp rod bolts for extra security. I wouldn't bother with the twin su carbs stick with the single and put the extra money into building in reliability That mini is determined to Kill me!!!! |
24th Nov, 2010 at 09:06:03am
Twin SU's already bought due to their bargainous price. I'm sure things like centre main strap and ARP bolts can be bought for myself as... say... an xmas present, meaning my budget is still in tact. lol
24th Nov, 2010 at 08:51:34pm
The twin SU as a bargain is always a good way to get money on it selling it back ...
Rusty by nature
24th Nov, 2010 at 10:53:36pm
ugh, this is so difficult to select the right bits. |
24th Nov, 2010 at 11:02:42pm
just stick a hif44 on it, better in every sense bar looks "Turbo's make torque, and torque makes fun"
388 Posts Member #: 442 Senior Member Manchester |
25th Nov, 2010 at 06:57:30pm
I was told that if you have pockets machined into the block you can still use a standard head.
319 Posts Member #: 1742 Senior Member essex |
20th Dec, 2010 at 10:17:10pm
yep you can put the 998cc head back on a pocketed block. They use the 998 head gasket as the template and the pockets dont go outside the gasket line. just slightly lower compression unless you skim the head a bit more. For turbo aplications i would strap the centre main it dosent really cost that much to do but do get it dome properly not just a geezer with a mill they do need to be surface ground and the crank jounal bore rechacked My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901 |
21st Dec, 2010 at 08:13:32am
A centre main strap is needed more on a high reving NA motor then a high torque turbo motor. So not really essential.
On 20th Dec, 2010 jlay said:
yep you can put the 998cc head back on a pocketed block. They use the 998 head gasket as the template and the pockets dont go outside the gasket line. just slightly lower compression unless you skim the head a bit more. For turbo aplications i would strap the centre main it dosent really cost that much to do but do get it dome properly not just a geezer with a mill they do need to be surface ground and the crank jounal bore rechacked http://www.twin-turbo.co.uk
21st Dec, 2010 at 08:45:43pm
Question about strap.
Rusty by nature
22nd Dec, 2010 at 08:22:57am
The hillclimber does have a strap, but it is 150bananas. Even so it is not the bottom end that takes the hammering on a turbo is it is not as necessary as you might intuitively think. http://www.twin-turbo.co.uk
22nd Dec, 2010 at 08:58:03pm
Bottom end, I just thought BL's worked on it when working on the Metro turbo so it might be required.
Rusty by nature
23rd Dec, 2010 at 03:32:33pm
Have a read of the metro turbo myths thread. The metty turbo bottom end is nothing special.
23rd Dec, 2010 at 09:56:51pm
I was just talking about mains ...
Rusty by nature
23rd Dec, 2010 at 09:59:57pm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=4724 http://www.twin-turbo.co.uk
