Home > General Chat > Brake question (Will 4 pot alloy 7.5`s fit behind rose petals or minilife wheels)
Sam
Member #: 1686
Oxford
Hello there fellas and the occasional lady.
I have a question, will the alloy mini spares calipers on a 7.5 inch disk go behind rose petals or mini life wheels? Without of course pushing the wheels out past the body line.
Thanks
Samuealle.
OMG Robert that's a big one
Wouldnt fit behind my rosepetals, dont know about Minilife
Sam
Member #: 1686
Oxford
Bit of a shame, cheers Paul.
miniminor63
Member #: 672
The oversills police
Oslo, Norway
Mlnilife:yes
miniminor63
Member #: 672
Oslo, Norway
Mlnilife:yes
t3gav
Member #: 229
Gavin@minispares.com
kent
Yes they will fit if you use the spacers supplied.
Sam
Member #: 1686
Oxford
Gavin, will this cause the wheels to protrude from the body work though?
t3gav
Member #: 229
kent
No they will fit inside.
Sam
Member #: 1686
Oxford
Cracking, cheers Gavin, paul and miniminor!
msn
Member #: 2051
both the newer billet minispares calipers and the older grey cast ones fit fine behind the minispares rosepetals. the spacer must always be used - this is only left out if the car is been used for F.I.A events (and the discs and cooper s calipers need to be machined to clear)
occasionally the bleed nipples will 'just' touch the wheel, but this is due to varience in the length of the bleed nipples rather than the fault of the wheels - you can either fit shorter bleed nipples (M10 thread) or relieve them a little.
all the clearance issues where checked before the wheels where signed off for manufacture
the minispares calipers also fit fine behind the minilife 4.5's
both types of wheel will fit within the standard archless body work with a 165 tyre fitted.
photos, as requested by gav!
hope this helps
Just remebered mine are 8.4 turned down, whether that makes a difference I dont know but they wouldnt go on my Sprint with or without the spacer
Paul
Sam
Member #: 1686
Oxford
msn mini spares north i presume?
Cheers for the images, cleared it up a treat
flat6
Member #: 1977
Cheshire
With MS 4 pots...
Sam
Member #: 1686
Oxford
cracking flat6. Like the car! Cheers :)
