Home > FAQ / Knowledge > straight cut drop gears
matt-atude
Member #: 8913
seaford, east sussex
hi all, right i got my straight cut drop gears installed and engine now running on idle there is some slight chattering whurring noise coming from the drop gear casing i know there meant to be alittle noisey on idle but when i press the clutch the noise goes, is this correct? just wanna make sure some one has experienced this.
cheers
matt
Sounds about right to me chief.
That is normal.
matt-atude
Member #: 8913
good to know cheeers guys
matt
EricsAmerica
Member #: 7891
Annapolis, MD USA
yeah....after you go deaf from driving with the whining, you won't even notice the chattering! *hehe!*
Eric
my pics.... http://www.fototime.com/inv/7AAF37CF3EFA956
dont drill your clutch cover,just make's it worse,
i concur, the first time i started up an engine with sc's i was a bit worried, but once under way they sound like a glorious 100hp blender
