Home > A-Series EFI / Injection > Injecting this manifold?
Yo-Han
Member #: 3228
North of the Netherlands
Ok, here it goes, after reading in books and checking threads on this forum about the work Paul S, Rod S and Graham T and ofcourse a lot of info by Jean I have found some courage to come before the knowledgable ones.. :)
So I want to inject this manifold.
When considering injection first I thought I should just make it a wet manifold.
But looking at the possibilities I should at least try to do it the ´proper´ way.
The problem with my manifold is that it was not initially designed to be injected.
Result is that I can´t put the injectors to close to the ports.
Then I thought about using pencil pattern injector shooting across the port.
Using the pencil pattern injectors I was hoping to bridge the distance and get more accurate fueling per port.
I was hoping pencil injectors would also reduce wall wetting and combined with injectors being timed after or in final phase of valve overlap reduce the charge robbing effect.
Am I correct that Rod S is also trying to work with timing to take care of the charge robbing effect? (I didn’t quite get the “skewed VE table” bit.)
The two main problems / questions I foresee are:
1.) Heatsoak; I was planning on using some slim EV6 injectors or anything alike. However the injectors still remain close to the exhaust manifold, about 15mm.
Now I can make some heatshielding but will be enough?
2.) Precision of injectors timing; how precise injectors would I need to get injection right if I want to do it this way? I was thinking about using 4x 400cc injectors (or something close).
My engine spec:
1293cc
9:1 CR
Mg metro cam
1:1.3 rockers
10psi boost
M45 supercharger
21352 pistons 8.4cc dish
Ported head (MSE6 with) 28cc chambers
Megasquirt + 2 widebands
Now, the mini is purely a hobby car, I enjoy working on it very much (I am a mechanical engineer) but also looking forward to driving it…
Not looking for mega performance, just the extra little kick in the butt… :)
So basically, is the idea I have worth a go or am I getting myself in a lot of trouble and should I better stick to the wet manifold plan and see if I can stick 2 injectors in the vertical bit before the manifold splits to the ports?
Your thoughts are much appreciated!
Edit typo..
Edited by Yo-Han on 8th Nov, 2010.
Dazed and Confused....
jbelanger
Member #: 831
Montreal, Canada
With 4 injectors set like that you wouldn't be using the siamese code but regular sequential injection. That also means that you need to have the injectors large enough at about 25% duty cycle for your power target.
Timing for the injection won't be that much more critical than it would be with the 2 pulse mode of the siamese code but the issue is that you'll have to use the trim tables to adjust the fueling between the inner and outer cylinders which means you'll need to copy the data from one pair of cylinders to the other pair. Also, you won't be able to use staged injection since you'll already be using the 4 injector drivers but that may not be an issue.
Jean
http://www.jbperf.com/
Although your drawing makes it look as if they are each aimed at their own specific inlet valve - hence I think Jean's suggestion of using regular sequential injection - another approach, with 4 injectors mounted like that, would be simply to wire them in parallel on each runner and use the siamese code as if there was only one larger injector on each runner.
This is what Paul has on his 998 at the moment although his 4 are in different positions without any angle towards individual valves.
Again, you would not be able to run staged injection if they were wired in pairs but the opposing angles would theoretically cancel out and you wouldn't need pencil type injectors as the two would would be mixing into one pulse.
Graham's initial work on staged injection shows that the angle of the injectors (if used independantly) does cause a further imbalance between inner and outer cylinders and Paul's staged injection design uses 3 per runner to cancel out any effects of angle.
If wired in parallel, 400cc each is going to limit power - Paul has 480cc paired together for approx 120HP and my initial setup is 1000cc individual injectors on each runner for an intended similar output.
No, it's the other way around...... With the siamese mode, the initial approach was to set the timing of the first and second pulses differently, thus affecting how much of the first pulse carried over to the "wrong" cylinder. Then in Paul's case with the hybrid single pulse mode, again, injection timing determines how much of the pulse ends up in each cylinder. What I have tried is setting the timing precise enough to avoid any carry over between cylinders and putting different values in the two VE tables - basically I have "skewed" one table by making the values 10% greater than the other table. There is no proof this will work at high loads yet as the car isn't fnished to be able to test it on the road, but the static testing I have done is very encouraging.
If you used normal sequential injection as Jean says (because you have pointed the injectors at the individual valves) the VE trim tables would be the same effect, ie, set the timing precisely and create a slightly different VE value for the inner and outer pulses so the physical pulse widths would be different.
My only comment, in addition to what has already been said, is that due to the turbulent flow within the port, it is highley unlikely that angling the injector towards a particular valve will have any benefit.
Once the fuel is in the port, it will travel in the same direction as the air flow, ie along the port centreline, then turn into whichever valve the air is going.
Having said that, the injector positioning will be fine and you have sufficient flexibilty within the code to get it to work, one way or another.
Are you sure that the manifold is going to clear the bulkhead?
Jean
Jean,
Are you sort of confirming that, in your opinion, there are now other ways of controlling injection to overcome the siamese port issues?
jbelanger
Member #: 831
Montreal, Canada
Jean
Jean,
Not really. What I'm saying is that with the additional constraints of regular sequential injection, you might be able to do something half decent. However, you can't use the injectors for more than about 25% duty cycle which means they need to be huge for the power produced.
I proposed that simply because the angling of the injectors will not produce the best setup for the siamese code because it does skew the fueling. So using either setup will bring its share of issues and I'm not sure which ones will be easier to deal with (mainly because of the small number of people using the siamese code).
I still think that the optimal solution is going to be with the siamese code and good injector placement. And it is probably the only way to achieve correct fuel distribution and certainly the only way of using more than about 25% duty cycle with the injectors (unless you go with a wet manifold setup). But if you have other constraints and are willing to live with a less than optimum setup then you may have other options. In that case, I'm not sure which setup is best and will depend on a lot of factors.
Jean
I think that if the angle of the injectors is equal and opposite, then wiring them in parallel and treating them as a single injector will give no more issues than normal siamese mode.
However, it does prevent staging being used unless a third one can be squeezed in.
Using "normal" sequential is an interesting idea but I think would only work if you could actually direct an injector at a specfic valve with absolute reliability and have really large sizes so as to keep the duty well under 25%.
But it's all experimentation at the moment so worth considering.
Yo-Han
Member #: 3228
Thanks for the input guys, much appreciated!
The main reason for going this route was because I can't really get the injectors any closer to the ports. I thought I could 'reduce' a bit of this distance by using pencil injectors.
Earlier I thought about putting 'ordinairy' injectors in the manifold but as they will be about 5cm away from the head this would pretty much make it a wet manifold and would not be able to use the Siamese code.
Summarising the input leads me to believe I would make it pretty hard on myself continueing this route.
I am going to see if there is a possibility to redesign the manifold, something like the manifold Paul S has on his 998 but than upside down.... This way creating space for two injectors on top of the runners much closer to the head.
But I really need to see how much space there is for this.
Your thoughts are more then welcome..
Thanks again for you thought!
(@ Paul S, yes, manifold clears the bulkhead.)
Yo-Han
Member #: 3228
Unfortunately I can't find enough time to make a proper manifold for using the siamese code.
So I have decided to settle for the less perfect wet manifold injection for now and try to make a proper manifold later.
I used an injector calculator which says I need just over 400cc/min to get at 125 hp (0.55 BFSC, 0.9 Duty cycle)
Now, I am planning to fit 2 MPI injectors into the 'vertical' runner before the T split.
Does this make sence (apart from going to wet manifold)?
Edited by Yo-Han on 19th Jan, 2011.
