| Home > Rod trials and testing > 16 months on..... | |||||||
7th Oct, 2010 at 06:14:07pm
Most of the wiring installed in the car but real problems with the TechEdge software talking to the MegaSquirt stuff (thanks to Ms Tobin....) I can get it to work on the desktop upstairs with the JimStim but not yet with the laptop outside.... so ignore evrything except the AFR figures.
7th Oct, 2010 at 09:19:51pm
I look forward to seeing your results. I must say that this is the method I thought would work and would be used when I first started with the code implementation.
7th Oct, 2010 at 09:30:10pm
Although I think I know what you mean, the term charge robbing is more to do with air than fuel. With a turbo and a moderate cam, charge robbing should not be a major issue.
7th Oct, 2010 at 09:42:27pm
I agree Jean, to make my theory work it relies on the actual injection pulse, including injector response time, fitting within the window at the actual load/RPM (ie, the actual transit time for any given flow rate of the mixture).
Edited by Rod S on 7th Oct, 2010. Schrödinger's cat - so which one am I ??? |
7th Oct, 2010 at 09:47:55pm
Paul, what I hope is that with very short runners the wall wetting should not be such an issue and with very large injectors and hopefully fast response times using low z, I can hit the window with enough margin to use VE tables to set the AFRs.
8th Oct, 2010 at 04:26:28am
Maybe its just the weather but I think I actually understood some of that ! |
8th Oct, 2010 at 08:44:18am
On 8th Oct, 2010 tadge44 said:
Maybe its just the weather but I think I actually understood some of that ! So once you've fitted your fancy modern GT series turbo, it will be followed by fuel injection ??? :) :) :) Once I've sorted out the logging link between TechEdge and the MS2 I'll do some simple (but methodical) experiments to see which is most effective (injection timing or VE tables) at bringing the AFRs together with my configuration. The problem is that between myself, Paul and Graham, we have three very different configurations so I wouldn't be surprised if the way that works best is different for each of us. Schrödinger's cat - so which one am I ??? |
8th Oct, 2010 at 12:28:19pm
One step at a time, I think ! |
8th Oct, 2010 at 12:35:14pm
Link between TechEdge and MS data sorted (a couple of files missing on the laptop.....) but before I do any serious testing, I thought I noticed yesterday that the AFR balance changed as the engine warmed up.
8th Oct, 2010 at 12:46:08pm
That's to be expected Rod. A lot more wall wetting when the engine is cold which means rich inners.
8th Oct, 2010 at 01:02:58pm
I assumed it was wall wetting from everything else discussed over the last two years, I'm just surprised at the difference when cold. Once I bring the AFRs back together at 85C (whether by timing or VE tables), it will be even worse when cold.
8th Oct, 2010 at 01:13:53pm
It's probably exzagerated by the fact that you are running far too lean.
8th Oct, 2010 at 01:20:59pm
On 8th Oct, 2010 Paul S said:
It's probably exzagerated by the fact that you are running far too lean. Ignore stoich and set warm idle at an AFR that gives a nice steady engine. Probably around 13.5:1. You will see them close up even when icy cold. Yes, I just thought about that while I was outside moving my data cables around - I remember you pointing out that yours were slightly on the rich side during warm-up at MITP whereas mine are obviously far too lean. I'll reset my warm-up curve whilst the engine is cooling down and try again once it's cold. Schrödinger's cat - so which one am I ??? |
8th Oct, 2010 at 06:41:19pm
With almost everything working.....
8th Oct, 2010 at 06:45:05pm
FAC?
8th Oct, 2010 at 06:59:12pm
Free Air Calibration :)
Edited by Rod S on 8th Oct, 2010. Schrödinger's cat - so which one am I ??? |
8th Oct, 2010 at 07:08:47pm
Ah yes, make sense now,
520 Posts Member #: 2093 Post Whore Grenoble, France |
8th Oct, 2010 at 08:47:53pm
I run 11:1 AFR @1200rpm when dead cold and 14.3:1 @880rpm above 75C. It's a bit rough when warm, becomes much more regular at 13:1 AFR but too close to 2.5% CO level limit. 13.5:1 at 80C gives around 1.5% CO. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
9th Oct, 2010 at 05:06:52pm
How about fitting the Innovate sensor in one of the sample chambers for a cross reference? Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
9th Oct, 2010 at 05:41:36pm
On 9th Oct, 2010 Paul S said:
How about fitting the Innovate sensor in one of the sample chambers for a cross reference? That's a good idea. However, I'm not really surprised to see a significant difference. I would suspect you'd see something similar if you were to try with controllers from different manufacturers and why it is important to use 2 identical controllers (or at least from the same manufacturer). I think that's another case where bananas (or some other more appropriate term) should be used instead of AFR or Lambda. Jean |
9th Oct, 2010 at 05:42:56pm
Nice idea, hadn't thought of that one.
Edited by Rod S on 9th Oct, 2010. Schrödinger's cat - so which one am I ??? |
9th Oct, 2010 at 06:06:03pm
Just to avoid confusion, at the moment it's two identical TechEdge controllers on two seperate wideband LSUs before the turbo - sample chambers are on siamesed exhaust 2/3 and the second one on single exhaust 4.
9th Oct, 2010 at 06:22:22pm
Rod,
12th Nov, 2010 at 10:30:07am
I took this snapshot a couple of days ago but only just transfered the file off the laptop (I was setting up an old laptop just for data logging).
12th Nov, 2010 at 12:08:30pm
Interesting........ Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
