Home > For Sale > T3 oil drain plate and pipe
tomf
Member #: 1746
Kent
Here i have up for sale a Mini/Metro turbo oil drain plate and a red silicon hose..
The oil return plate (the part that bolts to where the original mini fuel pump goes) is a genuine metro turbo item, and the silicon hose was brand new 1500 miles ago, so in excellent condition.
£22 + £3.75 P&P
jamz
Member #: 2292
Tool
Herne Bay, kent
im pretty sure your not suppose to use silicon hose for oil. thats why not many people have done this.
cant beat a good blowout.
If it's the proper silicone which is lined to handle oil like the standard Metro item then it's fine.
tomf
Member #: 1746
Kent
Im not sure tbh, i brought the hose that was advertised as a metro turbo t3 oil drain hose, so as it was sold for purpose i guess it is ok to use.
Does is have a black lining inside? If so this will be the Fluoro-lining and the hose should be oil tolerant.
