Page: |
Home > A-Series EFI / Injection > Trackday N/A 1380 | |||||||
857 Posts Member #: 1778 Post Whore Northants |
1st Sep, 2010 at 11:26:21pm
Well, we've done normal N/A, low boost FI and have high boost FI in the pipeline so for my old daily its time for high power N/A. This'll obviously be fuel injected using megasquirt and the siamese code :)
2nd Sep, 2010 at 03:13:35am
It's going to be interesting to see how tuning with the large overlap will be. I'd be surprised if you were able to use the single pulse with such a big cam.
![]() 5988 Posts Member #: 2024 Formally Retired Rural Suffolk |
2nd Sep, 2010 at 08:18:00am
The idle will be interesting with large injectors and a wild cam.
![]() 8604 Posts Member #: 573 Formerly Axel Podland |
2nd Sep, 2010 at 10:18:42am
Sounds like a lot of fun........ Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
49 Posts Member #: 4864 Member Northants, England |
2nd Sep, 2010 at 11:38:33am
Axel wont be happy! You'll be putting his rebuild to the back of the queue!
2nd Sep, 2010 at 11:45:39am
You boys have too many projects. lol If something is worth doing, it's worth doing half of. |
2nd Sep, 2010 at 02:29:36pm
It was your idea!
On 2nd Sep, 2010 Paul S said:
Sounds like a lot of fun........ ![]() |
2nd Sep, 2010 at 05:00:35pm
The timescale is relatively long as i don't have the funds at the moment and building the engine and box by itself is going to be pretty costly and hopefully by then MS3 Extra will have the siamese code, that'll then allow me to use the normal stepper motor for idle.
Edited by sturgeo on 2nd Sep, 2010. |
2nd Sep, 2010 at 05:00:52pm
Keep us informed on the FI. Could be interesting I seriously doubt it! |
![]() 1137 Posts Member #: 1450 Post Whore Near Paris - France |
2nd Sep, 2010 at 08:23:14pm
Idiotic question : am I right thinking the added value of FI on such a setup is only in fuel economy and smoother running ? Rusty by nature
They said "That sounds rough mate." I said "Cheers it cost me a fortune to make it sound like that!" |
2nd Sep, 2010 at 09:49:26pm
On 2nd Sep, 2010 Advantage said:
Idiotic question : am I right thinking the added value of FI on such a setup is only in fuel economy and smoother running ? We have yet to prove that the EFI will give more power, but there is every chance that it will. We can optimise the setup so that all cylinders run very close AFRs. How many people have actually put 2 or 3 wideband sensors on a Weber'd A Series? They may be missing out on power but do not realise it. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
3rd Sep, 2010 at 01:17:49am
On 2nd Sep, 2010 sturgeo said:
The timescale is relatively long as i don't have the funds at the moment and building the engine and box by itself is going to be pretty costly and hopefully by then MS3 Extra will have the siamese code, that'll then allow me to use the normal stepper motor for idle. Why can't you use the stepper motor with MS2? The hardware for the stepper controller is the same on both MS2 and MS3. And I wouldn't count on the siamese code to be on MS3 any time soon (or not so soon). By the way, there is no MS3 extra: there is only one code version which is MS3 and is done by the extra guys. Jean |
3rd Sep, 2010 at 06:03:28pm
Hi Jean, as this is going to be N/A i wouldn't mind giving nitrous a go further down the line and possibly control it via the megasquirt which as you know means using the stepper motor outs :(
4th Sep, 2010 at 02:43:13am
On 3rd Sep, 2010 sturgeo said:
Hi Jean, as this is going to be N/A i wouldn't mind giving nitrous a go further down the line and possibly control it via the megasquirt which as you know means using the stepper motor outs :( Not sure if it would be best to use a dry system and inject the extra fuel using the existing injectors (only really viable on the 1200cc jobbies) or use a wet system but then there is no control over what goes where ![]() Sorry, i meant MS3X. You need to use the stepper outputs only if you use 2 nitrous stages and you have COPs or if you use FIdle for something else. Since you want to use a wasted spark coil, you could use Fidle+D15 if you use 2 nitrous stages or simply Fidle. There is also the possibility of using the I/O Extender and have the nitrous I/Os done through the CAN bus. And that opens up a lot of additional possibilities such as reading the LC-1 data directly from the serial link instead of having the LC-1 transform the AFR data into an analog signal and having the MS retransform it into a digital data with all of the potential error sources such as noise, ground offset, 5V reference offset. And if/when you do go with the MS3, it can take advantage of the I/O Extender features even more. Jean |
4th Sep, 2010 at 01:43:55pm
Sorry Jean, we've been looking at the ms2 options table and hadn't realised that you could change it from using JS0 & JS2 to FIdle & D15 as displayed in tunerstudio.
4th Sep, 2010 at 04:11:07pm
I too have been going by what's on the printed options tables in the MS-Extra manual so I too hadn't realised there are actually more options than printed in that table.
4th Sep, 2010 at 04:45:36pm
The text here mentions the other options for nitrous. You're both correct that this table is not complete and should be updated.
Edited by jbelanger on 4th Sep, 2010. |
4th Sep, 2010 at 08:25:29pm
Idiotic question : am I right thinking the added value of FI on such a setup is only in fuel economy and smoother running ? We have yet to prove that the EFI will give more power, but there is every chance that it will. We can optimise the setup so that all cylinders run very close AFRs. How many people have actually put 2 or 3 wideband sensors on a Weber'd A Series? They may be missing out on power but do not realise it. I am far from an expert but I am working on it. As having the engine set up a litttle on the rich side does not lower power, how FI could better this (everything flowing the same quantity of air) ? The way I see it, FI can have the edge on transition modes and fuel economy but powerwise, should be the same. Ho, wait up. I forgot the carb is a self powered fuel injection so this self powering can be the extra power ... Sorry about the dumb question, I am trying to understand Rusty by nature
5th Sep, 2010 at 10:29:06am
Right, there are at least two reasons that EFi will give more power.
5th Sep, 2010 at 02:20:17pm
And as Paul has mentioned before, this unequal fuel distribution also means you have to compromise on the ignition timing. The advance is limited by the lean cylinder tendency to detonate so you either set the advance lower than what will yield maximum power or run the chance of a getting a holed piston.
6th Sep, 2010 at 09:41:40am
Re. the CANbus and what it can do, I've read up about the I/O extender on Jean's own site from the link Jean provided above, and read a lot more information abot it on his forum too.
6th Sep, 2010 at 09:55:49am
What interests me is that Jean has a SD card logger planned.
6th Sep, 2010 at 10:06:54am
You've obviously been reading up on it too :)
6th Sep, 2010 at 12:49:22pm
I would be very suprized if you see any realy over all power increce on this engine with FI over a big weber,
On 5th Sep, 2010 Paul S said:
Right, there are at least two reasons that EFi will give more power. Firstly, twin 40mm throttle bodies will flow better than any Weber/SU because of the lack of venturis/dashpots. Hence the engine will get more air. Secondly, the EFi can be set to ensure that all cylinders get the correct amount of fuel for maximum power. My tests with dual widebands on an SU back in December 2007 show that mixture distribution was very poor. Just because a single wideband says that the AFR is optimised does not mean that each cylinder is getting the best chance to make power. On 17th Feb, 2009 Rob H said:
Page: |
