Home > Wanted > Megajolt map for hot n/a 1380 engine
Hi
I require a base map to start tuning my n/a 1380.
If anyone has a map they would kindly donate me it would be appreciated, I'm not even doing any miles in it, just getting it running properly, then taking it to the rolling road.
spec is basically
1380
fully worked head
11.5:1 comp ratio
1.5 roller rockers
895 cam - similar to a 296.
Thanks
James
one on the link below also try the autosport labs forum
http://www.jamesfawcett.co/index.php?optio...&gid=3&Itemid=3
Prawn
Member #: 5232
basingstoke
I've got one on my laptop you can have mate, done by slark just last week for my 1380 (296 cam, med roadcomp head, 45dcoe, 11:1 Cr)
Pm me your email address and I'll send it over Tonight if it's any use to you
chris_evans
Member #: 11459
Cumbria
Sorry to resurrect this thread. I was wondering if you were both using MAP or TPS? I have pretty much the same set up as both of these engines, and I was under the impression that MAP would not be good for a 296 cam.
tps for n/a engine
