Home > FAQ / Knowledge > Thread Size - Oil Inlet Feed to Turbo
dan
Member #: 93
Finally managed to sort this out, thought this would be the best place to post it
thread sizes as follows, note there seems to be 2 types for the T2
T2 Turbo (R5 GTT, Silvia series etc)
7/16"x24TPI to JIC-4
or
1/2"x20TPI
T3 (Std Metro Turbo)
1/8" APPT 27TPI (APPT-American Parallel Pipe Thread)
remember the outlet on the block is 1/8" BSPT
contact iain for supply of oil feed hoses for your turbo!
Edited by dan on 6th Feb, 2005.
sorry to raise an old post
Im absolutley certain that the metro t3's thread is 1/8 npt 27tpi
then again im not 100% certain what the difference between npt and appt so they could the same?
TurboDave16V
Well, I have the Garrett production drawings for the metro T3 here, and it says:
1/8-27 DRYSEAL NPSF
So ner!
ha!
vegar
Member #: 189
Is there a place to get this hose online?
www.shag.no
T3 is 3/8 UNF. Any hydraulics place can make them for you. I use http://www.carlton-hydraulics.co.uk/ as they are local.
