| Home > 998cc > newbie gathering parts | |||||||
239 Posts Member #: 7577 Senior Member belgium |
8th Jun, 2010 at 02:31:10pm
hi all,
8th Jun, 2010 at 02:42:35pm
If you want to have a go yourself get a copy of vizzards yellow book and havea good read.
8th Jun, 2010 at 02:43:05pm
If you are using a standard 998 then and a 12G940 head then you will need dished pistons. Opening up the 940 chambers to the required 28cc is not a good idea on the 998. It may be better to use a decomp plate. Better still use a 12G295 head. You will not find a head to do what you want, you will need to have one modified.
8th Jun, 2010 at 03:03:13pm
As wil says, get a 12G295. It will be more than capable of delivering enough power to run into transmission issues so a 940 is not needed. The 295 will also require little or no chamber mods. He is also right about the fuel pump. Get one for a Metro turbo. I think the Bosch number ends in 044 but a search will confirm that.
Gary's description is best |
9th Jun, 2010 at 08:11:50am
does anyone have a 12g295 head lying around, i suppose it is not a straight swap, if i find an unmolested head i need to skim it and flow all ports right?
9th Jun, 2010 at 08:15:51am
You don't want to skim a 295 head for forced induction. It gives a very good (i.e. low) compression ratio as standard. On 11th Feb, 2015 robert said:
9th Jun, 2010 at 08:23:05am
true, the lower the compression the better, but if you buy an old, left in the barm for odd years, head this will certainly need to be done i suppose.
9th Jun, 2010 at 11:32:44am
i would have the head checked and skimmed if needed, a better gasket seal is better than ~1/2cc lost imo
Yes i moved to the darkside |
9th Jun, 2010 at 02:10:10pm
As far as I know, Carl S has an unskimmed 12G295. He may be worth sending a PM On 12th Nov, 2009 Paul S said:
10th Jun, 2010 at 09:49:48pm
via the search function on this forum i already found the head, pmmed carl
30th Sep, 2010 at 11:30:18am
30th Sep, 2010 at 11:40:48am
Plenum bolt size:
9th Oct, 2010 at 10:08:51am
thanks,
