Page: |
Home > Shows > Lean off pipe | |||||||
80 Posts Member #: 4178 Advanced Member Chesterfield |
28th Apr, 2010 at 12:05:18am
Hello boys and girls, can anyone tell me if it is ok to use the stub on the top of the carb to connect to boost gauge to. I've blanked the pipe from the side of the carb but thought blanking the other seemed a waste of a vacuum source. I am nobody, nobody's perfect. Therefore I am perfect |
9502 Posts Member #: 1023 Post Whore Doncaster, South Yorkshire |
28th Apr, 2010 at 02:33:22am
from memory its not a straight through connection so a provisional no from me Yes i moved to the darkside
3004 Posts Member #: 2500 Post Whore Buckinghamshire |
28th Apr, 2010 at 07:04:50am
Worked OK for me , once I had run a drill through it (there is a little ball and spring non return valve in there IIRC)
28th Apr, 2010 at 07:49:52am
On 28th Apr, 2010 tadge44 said:
Worked OK for me , once I had run a drill through it (there is a little ball and spring non return valve in there IIRC) Wish I hadn,t though, because the carb is now spoiled and I cant find another so that I can try re-connecting this pipe. O/T but if you want to try the lean-off pipe again and have drilled out the NRV, just put one in the pipe run. Just use the cheap plastic type that are used on aquariums / fish tank air systems for a trial (about £1 each off eBay) and if succesful you can get small metal ones actually meant for fuel systems. Schrödinger's cat - so which one am I ??? |
28th Apr, 2010 at 07:53:10am
I'm looking forwards to this show!!!!
6549 Posts Member #: 1149 #1 Basshunter Fan Force Racing ICT Dept Manager Miglia Turbo Am frum Yokshyer tha noes! |
28th Apr, 2010 at 08:58:24am
I was just thinking this lol. And i would agree with keeping it aswell.
On 28th Apr, 2010 wil_h said:
I'm looking forwards to this show!!!! But as above, no. And in all cases I would advise keeping the lean-off pipe. Just buy a spacer with a take-off in it. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
3588 Posts Member #: 655 Post Whore Northern Ireland |
28th Apr, 2010 at 10:37:41am
It should not work correctly fora gauge. Its a spark port, so only gives vacuum at part throttle, although boost properly.
28th Apr, 2010 at 11:36:19am
Agreed |
Page: |
