| Home > 998cc > Another 998 compression question | |||||||
55 Posts Member #: 909 Advanced Member |
18th Apr, 2010 at 06:15:19pm
I've used the search feature and have not found an instances where someone is running a low compression in a 998. We are about to build/bodge a 998 turbo for an endurance "race" and are looking for some wisdom.
18th Apr, 2010 at 06:23:45pm
I've never seen A+ dished pistons on a 998 and I don't believe that they were ever fitted as standard on the A+.
18th Apr, 2010 at 06:50:02pm
Metro Van low comp 998 had dished pistons. I have a damaged example of a dished 998 piston. On 11th Feb, 2015 robert said:
18th Apr, 2010 at 08:59:48pm
Yep, A+ 998 came with dished pistons in some forms, all 6cc. I've see both slipper and fullskirt type.
66 Posts Member #: 8258 Advanced Member |
18th Apr, 2010 at 09:53:14pm
If you're using a lot of boost, 8 or 8.5:1 is better.
18th Apr, 2010 at 10:56:37pm
On 18th Apr, 2010 Laurence said:
If you're using a lot of boost, 8 or 8.5:1 is better. If you need reliability, fit uprated/forged pistons, standard A+ pistons will break-up/melt. (I ran a N/A MG Metro engine with std pistons for a few years & a chunk of a piston crown disappeared!) Fit uprated Mains & Big-end shells. Fit turbo head-gasket & manifold gasket. Torque head-nuts (oiled) to 55lbf ft Fit turbo oil-pump. Fit Grey clutch cover & AP race clutch plate (if you're using pre-Verto clutch.) If you're using Verto clutch, use Turbo clutch cover at least, or use RTS (Roberts Twin Spring) Verto cover. Fit lightened flywheel. Use Millers Classic Mini 20W/50 oil or similar which is formulated for engine/box/diff combination . www.minispares.com for all the above bits + advice. This is so much incorrect information here. There is no such thing as a turbo head gasket for a 998. You cannot get a turbo oil pump. A standard one will be fine. A verto clutch of the correct spec will hold up to 100 lb ft of torque. That will do fine. I'm using one at 105 lb ft and 120 hp. A lightened flywheel will not be necessary. Ask the guy running twelve second quarters on a standard flywheel. Laurence, please check your facts before posting. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
18th Apr, 2010 at 11:34:56pm
my thoughts exactly paul
19th Apr, 2010 at 06:58:55am
Thanks for the feedback. You have me questioning my compression calcs now, too. I did it several months ago and because the compression factored out so low we ended up building another block using flat tops. Using _.030 flat tops and the same head I had initially cc'd for the calcs for the turbo 998 we've ended up with like 11:1, Hmmm. I'll have to re-measure.
19th Apr, 2010 at 07:05:28am
On 19th Apr, 2010 Spank said:
If I can't find a metro cam, do either of those others sound ok? For the turbo app, do I want dual pattern cam or the identical inlet/exhaust? As far as I know, the reason the Metro cam works s well in turbo applications is due to the relatively long exhaust duration Heres some good info on cam timing figures for some standard and aftermarket cams http://www.mlmotorsport.com/index.php?opti...apper&Itemid=57 About the turbo oil pump in a small bore block, I (watched whilst Paul) took the drive out, milled the flats back and then shortened the whole drive shaft. It's quite simple really On 12th Nov, 2009 Paul S said:
Gary's description is best |
![]() 4633 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
19th Apr, 2010 at 08:21:47am
RE: Big bore head-- it's what I've got already and 12G295 heads are tough to find. And not that I can speak for lawrence, but perhaps because I mentioned I was going to use a big bore head that he advised I used a turbo gasket (??). Would be some odd machining for those rings in a 998 block no ? You're thinking of the Group "A" Turbo gasket, which requires machining, the standard Turbo one doesn't. |
19th Apr, 2010 at 09:31:23am
If you're using a lot of boost, 8 or 8.5:1 is better.. What is a lot of boost? 9:1 is great for 12psi with an IC On 18th Apr, 2010 Laurence said:
If you need reliability, fit uprated/forged pistons, standard A+ pistons will break-up/melt. (I ran a N/A MG Metro engine with std pistons for a few years & a chunk of a piston crown disappeared!). You site one example here, I suspect it was not the pistons at fault. I used standard 998 pistons (that had done 70,000 miles) and they are still going. I have never used forged pistons and have no reliability issues. On 18th Apr, 2010 Laurence said: standard are fine, If you understand how turbo engines make power, then you would understand why.
Fit uprated Mains & Big-end shells.. On 18th Apr, 2010 Laurence said:
Fit turbo head-gasket & manifold gasket. Torque head-nuts (oiled) to 55lbf ft. BK450 if using a 12G940, but I wouldn't use anything else. If using a 295 you can't use the BK450. On 18th Apr, 2010 Laurence said:
Fit turbo oil-pump.. It disen't fit. But again I used a 70,000 mile old standard 998 oil pump no problems. On 18th Apr, 2010 Laurence said:
Fit Grey clutch cover & AP race clutch plate (if you're using pre-Verto clutch.) If you're using Verto clutch, use Turbo clutch cover at least, or use RTS (Roberts Twin Spring) Verto cover. . this guy is after 80bhp!!! gry is total overkill, standared verto will cope with this no problem. On 18th Apr, 2010 Laurence said:
Fit lightened flywheel.. Why? On 18th Apr, 2010 Laurence said:
Use Millers Classic Mini 20W/50 oil or similar which is formulated for engine/box/diff combination . . If you have lots of money yes, there are cheaper options, but semi-synthetic is a must. I know a lot of this is answered above, but I thought that it was worth re-itterating before this type of incorrect info spreads around the world. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
![]() 1137 Posts Member #: 1450 Post Whore Near Paris - France |
19th Apr, 2010 at 09:41:34pm
www.minispares.com for all the above bits + advice. Oups, if this was advertisement, it seems not to have hit the target ... Rusty by nature
They said "That sounds rough mate." I said "Cheers it cost me a fortune to make it sound like that!" |
4th Aug, 2010 at 09:47:29pm
Sorry to hi jack this post, but I have some questions regarding this topic and rather than flood the forum I thought I would "recycle" an old thread!
388 Posts Member #: 442 Senior Member Manchester |
6th Aug, 2010 at 07:26:17pm
Retarding the ignition will not reduce compression. All this does is change the time at which the spark happens.
6th Aug, 2010 at 08:50:29pm
Get yourself a 12G202 or a 12G295, you will lower your CR and get the added bonus of the bigger valves.
Rusty by nature
30th Oct, 2010 at 08:41:54am
Revisiting this thread and I guess would like someone to check my math: We're still looking to do the budget build using existing parts which is basically a +.020 998 with a metro turbo setup (carb and manifold). Standard boost likely.
520 Posts Member #: 2093 Post Whore Grenoble, France |
31st Oct, 2010 at 08:42:42pm
I must have missed something, I still don't understand why are you trying to use the g240 head ? If you are looking for reliability then I don't think pockets are better than a std g295 head (I bought two of them in the US 2 years ago, $75 each, from Healey engines). Pockets are a potential source of ping as they present sharp edges everywhere.
std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
1st Nov, 2010 at 05:40:17am
Main reason is I need to keep it below $500 total cost (including car purchase) and am trying to use existing parts-- stuff I already have stashed. I hear you on the edges/hotspots/detonation worries, for sure. Head rebuild and skimming (assuming no new parts and not including purchase price of the head) will run $185 US minimum. I have a good 12G1316 head now and compression will be around 9:1 as I've figured it (with the above supplied info). And I've already got the metro setup with the T3 turbo so can't go about sourcing another at this first bodge... er... I mean "try".
2nd Nov, 2010 at 07:06:28pm
I see.
