Page: |
Home > Technical Chat > COP | |||||||
617 Posts Member #: 6558 Post Whore Pueblo, Colorado, USA |
14th Apr, 2010 at 02:14:36pm
I was wondering if anyone had gotten COP to work yet? And if they've found any benefits? I've got a mate who's parting up his project and has some brand new AEM pencil COP's that he'll give me for a bargain and I'm wondering if it's worth my trouble on the MS.
11046 Posts Member #: 965 Post Whore Preston On The Brook |
14th Apr, 2010 at 03:06:36pm
453 Posts Member #: 6449 Senior Member Brisbane, Australia |
14th Apr, 2010 at 03:24:03pm
Whats it stand for?
In boost we trust |
14th Apr, 2010 at 03:25:00pm
Coil on plug, i googled it.
In boost we trust |
14th Apr, 2010 at 03:41:21pm
Assuming by MS you mean MegaSquirt, you will tie up two more CPU ports to drive COP or CNP or low level logic or any 4 channel ignition system.
2909 Posts Member #: 83 Post Whore Glasgow, Scotland |
14th Apr, 2010 at 05:09:24pm
I fire my vw cop units waisted spark, only requires 2 outputs ad works fine :) turbo 16v k-series 11.9@118.9 :)
14th Apr, 2010 at 05:20:36pm
Your running a twink head though right evolution? I think I might agree with you Rod. I was just running a thought, as I would rather save the ports for the eventual efi.
14th Apr, 2010 at 05:22:31pm
On 14th Apr, 2010 evolotion said:
I fire my vw cop units waisted spark, only requires 2 outputs ad works fine :) That's a novel approach :) Do you drive the four paired together from two ignitor ICs (as per coilpack) or are they logic level units ??? Schrödinger's cat - so which one am I ??? |
869 Posts Member #: 2443 Post Whore Cheshire |
14th Apr, 2010 at 10:14:05pm
On 14th Apr, 2010 best_stig said:
Whats it stand for? Cam Over Piston? |
14th Apr, 2010 at 10:40:17pm
I fire my vw cop units waisted spark, only requires 2 outputs ad works fine :) That's a novel approach :) Do you drive the four paired together from two ignitor ICs (as per coilpack) or are they logic level units ??? If they don't have built-in ignitors, the way to go is to have 2 ignitors per ignition channel. You should not try to run 2 coils from the same ignitor. And some COPs will work fine run in wasted spark bot not all since you're firing them twice as often as they would be in a true COP setup. And from what I've read, some VW units don't like to run that way. Jean |
6745 Posts Member #: 828 Post Whore uranus |
15th Apr, 2010 at 08:04:35am
i fire my hyabusa cop's wasted spark too ,on the bike . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
15th Apr, 2010 at 08:45:25am
The vw units are unreliable at best but I havnt had any issues waisted spark to over 8000rpm. The cop I run have a low impedance pull down resistor on the logic level input (built in ignitor), but driving two off the same PNP driver is ok as it's just a logic level input, would never run two coils off the same ignitor!
I fire my vw cop units waisted spark, only requires 2 outputs ad works fine :) That's a novel approach :) Do you drive the four paired together from two ignitor ICs (as per coilpack) or are they logic level units ??? If they don't have built-in ignitors, the way to go is to have 2 ignitors per ignition channel. You should not try to run 2 coils from the same ignitor. And some COPs will work fine run in wasted spark bot not all since you're firing them twice as often as they would be in a true COP setup. And from what I've read, some VW units don't like to run that way. Jean turbo 16v k-series 11.9@118.9 :)
15th Apr, 2010 at 10:13:46am
I use the Hyabusa coils wasted spark on individual igniton drivers. I dont see these Denso coils having a problem on wasted spark as they can run silly rpm anyway, and they dont live at 8000rpm all the time.
3588 Posts Member #: 655 Post Whore Northern Ireland |
15th Apr, 2010 at 10:22:38am
There will be little difference in performance between a 4 tower coilpack and a COP setup.
15th Apr, 2010 at 11:36:26am
Site Admin 9403 Posts Member #: 58 455bhp per ton 12 sec 1/4 mile road legal mini Sunny Bridgend, South Wales |
29th Oct, 2014 at 09:48:49pm
On 15th Apr, 2010 Sprocket said:
I use the Hyabusa coils wasted spark on individual igniton drivers. I dont see these Denso coils having a problem on wasted spark as they can run silly rpm anyway, and they dont live at 8000rpm all the time. The Denso coils are very compact and only 2 wires each and a primary resistance of around 1.6 ohm. Just beware of the CDI coils with supper low primary resistance of 0.6 ohm!! Did you have to change the dwell or anything to get these to work ok? How well do the fit in the k head? I'm looking for a tight seal between the cop and the head to keep debris away from the base of the plug hole. Team www.sheepspeed.com Racing
30th Oct, 2014 at 01:57:26am
What are those COP's sprox?
30th Oct, 2014 at 08:55:42am
I'd presume they are a bike type. there are lots of Denso ones available form bikes. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
30th Oct, 2014 at 10:01:22pm
Those coils are Denso 129700 - 4150 from a suzuki GSXR. They are inductive, so the ECU will need four IGBT outputs to drive them if you want to use them.
31st Oct, 2014 at 11:33:34am
I'm thinking of the change to COP to save some weight, I like the look of the VAG TFSI 1.4. do you know what each of the 4 pins are for on them? Team www.sheepspeed.com Racing
31st Oct, 2014 at 07:35:14pm
Page: |
