Page: |
Home > 998cc > 998 turbo build | |||||||
![]() 109 Posts Member #: 8630 Advanced Member |
17th Mar, 2010 at 12:18:29pm
hi all i have a 998cc city E and want to go down the turbo route
17th Mar, 2010 at 12:21:21pm
http://www.turbo-mini.com/62147.html On 11th Feb, 2015 robert said:
i tried putting soap on it , and heating it to brown , then slathered my new lube on it ![]() |
17th Mar, 2010 at 01:47:09pm
thats good advice but it still doesnt answer my question ive been looking for a metro turbo fuel pump and 2 comes up the mechanical and a electric one so would i use the mechanical one |
17th Mar, 2010 at 01:49:02pm
take the mechanical pump off. you can modify a fuel pump blank to use as an oil return for your turbo. If something is worth doing, it's worth doing half of. |
493 Posts Member #: 3894 Senior Member sallys gap. garden of Ireland |
17th Mar, 2010 at 01:49:47pm
a blanking plate across this hole in the block, or an oil return from turbo to block are the two solutions for this.
Edited by 1972-ANGUS on 17th Mar, 2010. |
17th Mar, 2010 at 01:54:48pm
cheers for the help can u buy these blanking plates or do i need to make one |
17th Mar, 2010 at 01:56:32pm
Either. you need an oil return so would have to modify it.
![]() 5988 Posts Member #: 2024 Formally Retired Rural Suffolk |
17th Mar, 2010 at 01:57:17pm
On 17th Mar, 2010 smudger483 said:
cheers for the help can u buy these blanking plates or do i need to make one http://www.minispares.com/Product.aspx?ty=...LANKING%20PLATE ...and from loads of other Mini specialists. EDIT - you can take this plate and modify it for your oil return - that's what I did - depending on your turbo's oil return configuration. EDIT 2 - John beat me to it although with a slightly wierd shaped plate...... Edited by Rod S on 17th Mar, 2010. Schrödinger's cat - so which one am I ??? |
17th Mar, 2010 at 02:00:58pm
and whats the bst electric fuel pump to go for and where would you wire this in your loom
17th Mar, 2010 at 02:08:08pm
Do a search on fuel pump you will find all the answeres. Basically you need an injection type fuel pump. There are lots of ways to wire one in most people interlock it with the oil pressure. http://www.twin-turbo.co.uk
17th Mar, 2010 at 02:11:42pm
hi smudger,
17th Mar, 2010 at 02:12:00pm
and whats the bst electric fuel pump to go for and where would you wire this in your loom sorry for all the questions its my first mini build http://cgi.ebay.co.uk/NEW-Electric-Fuel-pe...=item41482fbf5a It will do injection which is higher pressure but, so long as your regulator is in good working order it will be fine for the lower pressures of the SU carb under boost. It's the closest equivilant of the MPI pump which lots of people use. To wire it in safely use a relay controlled by something like oil pressure (as per the original Metro Turbo) and put an inertia switch in line (like all modern cars) to kill it in the event of a crash. EDIT - too slow typing again, I'm off back out to the garage..... Edited by Rod S on 17th Mar, 2010. Schrödinger's cat - so which one am I ??? |
17th Mar, 2010 at 02:17:21pm
thanks for all the help guys and i will take what you said john on board
17th Mar, 2010 at 02:30:45pm
thanks for all the help guys and i will take what you said john on board thanks again Great stuff smudger. Welcome to TM btw if I didn't say so in your introduction thread! If something is worth doing, it's worth doing half of. |
Page: |
