Page: |
Home > A-Series EFI / Injection > Tuning MegaSquirt for 998 NA | |||||||
608 Posts Member #: 1106 Post Whore Hungerford, Berks |
16th Mar, 2010 at 12:16:23pm
Following on from my build thread - http://www.turbominis.co.uk/forums/index.php?p=vt&tid=334028
Edited by Graham T on 16th Mar, 2010. ’77 Clubman build thread
857 Posts Member #: 1778 Post Whore Northants |
16th Mar, 2010 at 12:44:43pm
Looking good, once you get them as close as possible just increase the fuel via the VE table to slightly richen it up and jobs a goodun!
16th Mar, 2010 at 01:08:39pm
Although it's only an NA 998, it is Unreal to drive, in comparison to a week ago. Without knowing any power/torque figures, before or now, I'm convinced that it pulls better, right from tick over. much smoother acceleration also.
16th Mar, 2010 at 01:10:32pm
Moving forward for sure...
16th Mar, 2010 at 01:16:33pm
On 16th Mar, 2010 Graham T said:
The only downer at the moment is tick over. I got over the cold start issue, but cold tick over is very lumpy. outers way to lean, so I'm playing with the inj timing load bins to accomodate this. I hope. I have hot tick over at around 1300rpm, again lower that this and it's lumpy, but again, I think its just down to inj timing. Hot tick over AFR's are 10 outers and 7.5 (probably more) inners. Have you checked the calibration of the temperatures sensors, specifically CTS. I had no problem getting 13-14 at tickover on both inners and outers once MS had the right temperatures (so it knew the engine was hot). Also look at your warm up enrichment table. Schrödinger's cat - so which one am I ??? |
16th Mar, 2010 at 01:22:44pm
Yes, The second graph is a slightly longer time frame, so shows higher RPM. I also noticed the greater distance between AFR's at the higher RPM's.
16th Mar, 2010 at 01:40:25pm
Re the pulse timing, always bear in mind transit time.
16th Mar, 2010 at 01:54:29pm
I'll move the wide band controller. It's next to the fuse box that supplies the rest of the car. Silly place, but I ran out of room. It was one of the "refinements" I needed to do.
16th Mar, 2010 at 02:41:43pm
That is looking good. It took me a couple of years to get them that close.
21st Mar, 2010 at 09:17:24am
Another set back. I think...
21st Mar, 2010 at 09:30:30am
Your diagnosis is sound, unless you've accidentally put the settings wrong in the msq so it's not expecting the second trigger.
21st Mar, 2010 at 09:43:33am
I tested the input and I'm getting around 12.5V.
21st Mar, 2010 at 09:52:47am
Just thought.
Edited by Graham T on 21st Mar, 2010. ’77 Clubman build thread
21st Mar, 2010 at 09:53:48am
So far as I'm aware, trigger wheel settings should be "second trigger active on" EITHER rising OR falling depending on where your switch switches on and off (I have mine on rising edge to get it the set margin away from the 36:1 missing tooth as the falling edge was quite close).
21st Mar, 2010 at 09:57:52am
Second question, no the ones in red need a reboot (although some seem to work without) and there are several settings you must NEVER change with the engine running.... Schrödinger's cat - so which one am I ??? |
21st Mar, 2010 at 10:00:40am
Yes, second trigger should be set to rising edge.
21st Mar, 2010 at 01:27:39pm
I have set the second trigger to rising edge (and tried falling edge, just for grins). No joy.
21st Mar, 2010 at 01:39:28pm
You can have a look at the composite logger. Select the diagnostics tab in TunerStudio and you will have a graph of what MS is seeing from your two tach inputs.
21st Mar, 2010 at 01:57:59pm
I don't know if this will help, but this thread details how I set up and tested my cam sensor:
21st Mar, 2010 at 02:13:54pm
If the test LED/resistor doesn't flash when cranking (but lights when connected to 12V) then either,
21st Mar, 2010 at 06:17:42pm
Jean, Heres a screen dump of the composite logger
21st Mar, 2010 at 06:30:25pm
Graham,
21st Mar, 2010 at 06:53:00pm
This is what it should look like:
22nd Mar, 2010 at 09:27:19am
After reading the thread Paul posted a link to earlier, I now have a better understanding of the hall sensor and how it works.
22nd Mar, 2010 at 09:43:49am
Yes, the sketch is "wrong" but the test circuit on the breadboard is correct and should match what is inside your MS2 box if you wired it as per Paul's original drawing. Just touch your yellow wire to ground (black) first to check the LED is the right way around Schrödinger's cat - so which one am I ??? |
Page: |
