Home > 998cc > 998 cam
TurboTom
Member #: 7936
DK-8450 Hammel. Denmark
Hi.
I have a 998cc mini thirty(1989) with a defect camshaft. I havent removed the cam yet, as my garage is unheated, but i would like to buy the cam now.
Does anyone know what oilpump drive to choose ?
In the old days there was a difference in lenght from smallbore to bigbore. is it the same with a+ engines?
Thanks
If i have more toys than you when i die, I WIN
All A+ are slot drive, that is if if is the standard oil pump it left the factory with.
the.eliminator
Member #: 8323
Bedfordshire
metro cam (not turbo) are good *wink* and will fit straight in
Austin Mini Designer Stage 1 N/A 1098
Future build- 1275 with Gen' ERA Turbo setup
On 31st Oct, 2007 DemonPixie said:
Well I think you're all a bunch of nutters....
An MG metro cam (non turbo) are good yes. However the standard metro cam is not so good. The standard turbo cam is the same as the standard metro cam.
Please ensure you get your replies factually accurate.
