Page: |
Home > General Chat > Speed Sensor for speedometer | |||||||
3rd Feb, 2010 at 12:29:17pm
Hi, has anyone got any pics showing how a mounted / fitted speed sensor for a speedometer?
4306 Posts Member #: 1321 Post Whore Wiltshire |
3rd Feb, 2010 at 12:45:49pm
I made an aluminum bracket that mounted to the brake caliper and cable tied the speed sensor magnet from my mountain bike to the wheel.
3rd Feb, 2010 at 01:21:43pm
so brake caliper and brake disc could be ok.. |
Site Admin ![]() 9404 Posts Member #: 58 455bhp per ton 12 sec 1/4 mile road legal mini Sunny Bridgend, South Wales |
3rd Feb, 2010 at 02:18:35pm
Doesn't the sensor get too hot on the brake caliper? Team www.sheepspeed.com Racing
3rd Feb, 2010 at 03:03:53pm
On 3rd Feb, 2010 Jimster said:
Doesn't the sensor get too hot on the brake caliper? are you using gps now? where did you have yours before going fancy? |
3rd Feb, 2010 at 03:49:46pm
Doing mine like Mike's albeit with a threaded sensor through the backplate http://www.turbominis.co.uk/photo/239/ |
3rd Feb, 2010 at 04:10:30pm
Mine does use GPS for speed, but I have wheel speed sensors for data logging. Although this is easy for me as I have disks on the back.
![]() 460 Posts Member #: 843 Senior Member Stoke-on-Trent. Duck. |
3rd Feb, 2010 at 04:42:07pm
On 3rd Feb, 2010 gavin@minispares.com said:
Doing mine like Mike's albeit with a threaded sensor through the backplate http://www.turbominis.co.uk/photo/239/ Same, though my sensor "detects" anything ferrous so I have a short bolt in the hub's-tapped-hole (for the drum screw) that sits just off the sensor. I know a pic would be useful here but I don't have one. At least not yet any way... Dave. |
3rd Feb, 2010 at 05:03:18pm
Good idea Pottsy, sure Mike's setup uses the back of the head of the stud instead of a magnet. |
3rd Feb, 2010 at 06:08:09pm
nice - thanks for the link.
![]() 4629 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
3rd Feb, 2010 at 06:10:00pm
Mine's mounted in the backplate of the rear drum. It picks the signals of the wheel stud heads passing over it. |
3rd Feb, 2010 at 08:44:36pm
On 3rd Feb, 2010 Turbo Phil said:
Mine's mounted in the backplate of the rear drum. It picks the signals of the wheel stud heads passing over it. Phil, have you got alloy hubs then? Otherwise how does the sensor distingush between the studs and the hub? I guess it works though?! I ask as this was my concern - with the limited space available trying to keep the stud near the proximity sensor but away from the hub face, without the now long-rotating-stud wiping out bits of brakework! Dave |
3rd Feb, 2010 at 08:46:06pm
Doesn't the sensor get too hot on the brake caliper? The aluminium plate attatches to the back plate, but passes over the caliper. It seems fine, even after I cooked the brakes at combe. On 7th Oct, 2010 5haneJ said:
3rd Feb, 2010 at 09:31:52pm
On 3rd Feb, 2010 Pottsy said:
Phil, have you got alloy hubs then? Otherwise how does the sensor distingush between the studs and the hub? I guess it works though?! I ask as this was my concern - with the limited space available trying to keep the stud near the proximity sensor but away from the hub face, without the now long-rotating-stud wiping out bits of brakework! Dave No, just the ordinary hubs. It works fine & has done for the last 6-7 years. |
4th Feb, 2010 at 09:24:31am
![]() 243 Posts Member #: 1261 Senior Member Droitwich |
2nd Jun, 2021 at 01:32:05pm
Thread revival.
3590 Posts Member #: 655 Post Whore Northern Ireland |
3rd Jun, 2021 at 07:35:02pm
what you need etc...will depend on what the speedo is and what sensors or triggers it needs. 9.85 @ 145mph
3rd Jun, 2021 at 09:49:30pm
I'm going to use my dta to read the signal so it can be anything. I like the idea of using the threaded vr style one reading the studs on the rear. I had a quick look but they come in loads of different lengths and prices from £20 to £130. Would be good to know what people have used in the past, can't imagine you've got to spend 130 quid to get one that's reliable? |
2636 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
3rd Jun, 2021 at 10:16:53pm
Try www.digital-speedos.co.uk, they made me a sender unit that mounts on the speedo drive that produced the correct signal/wave for a Stack race dash I was going to use.
4th Jun, 2021 at 07:42:30am
ah thats cool, cheers for that
4th Jun, 2021 at 10:34:26pm
Depending of your wave requirements I still have the sender unfitted/unused if its of use to you?
7th Jun, 2021 at 07:21:20am
Ah thanks for the offer but I've sorted it now |
8th Jun, 2021 at 06:16:12pm
I made a bracket mounted to the output flange bolts, then just cable tied a magnet to the pot joint. Works well. On 7th Oct, 2010 5haneJ said:
9th Jun, 2021 at 02:19:59pm
If you're using an A series box we stock these http://minispares.com/search/classic/gsd100.aspx |
Page: |
