Home > A-Series EFI / Injection > Self learning fuel injection
hydrolastic
Member #: 6668
Hello Anybody here ever think of using something like this? http://www.fuelairspark.com/ezefi/default.asp
Racecar spelled backwards is Racecar
sturgeo
Member #: 1778
Northants
That's ok for a "normal" engine but doesn't work with the Siamese cylinder head.
As Sturgeo says, fine on an individual port setup like most engines - almost all aftermarket systems can "learn" on a simple setup - but not on siamese ports.
hydrolastic
Member #: 6668
Yes your right, But what about a bmw head?
Ben H
Member #: 184
Melton Mowbray, Pie Country
Once you get rid of the 5 port head and have one inlet per cylinder it becomes 'normal' and self learn will work.
http://www.twin-turbo.co.uk
