Page: |
Home > Wanted > WANTED: Mini Special Alloy Wheel Nut Covers & Centre Caps | |||||||
10021 Posts Member #: 1456 Mongo Barnsley, South Flatcapshire |
11th Jan, 2010 at 10:43:35am
As per the subject line.
5417 Posts Member #: 6181 Double hard bastard brookwood woking |
11th Jan, 2010 at 09:47:29pm
Hi mate i have some with covers will have a look. I have started posting on Instagram also my name on there is turbomk1golf
12th Jan, 2010 at 09:44:58pm
Hi mate i have found the nuts but i have lost 2. If they are what you need pm me your email as i can see pms but cant reply to pm s
13th Jan, 2010 at 03:12:12pm
Yeah looks good to me.
1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
17th Jan, 2010 at 04:39:36am
John.
17th Jan, 2010 at 11:11:03am
I've got a set of nuts like those already Richard. Thanks for the offer though. If something is worth doing, it's worth doing half of. |
509 Posts Member #: 1027 Post Whore Germini, black forrest |
17th Jan, 2010 at 11:35:57am
The nuts in the picture are not the correct type for a Special wheel! The Special wheel's nuts have a STEEL washer which holds them on the car... The ones pictured look like Rover 12" steel wheel nuts with the plastic washer.
Edited by Asphalt on 17th Jan, 2010. [X] nail here for new monitor |
784 Posts Member #: 912 Post Whore North Yorkshire |
17th Jan, 2010 at 12:35:07pm
You can still buy these nuts new you know.
I drill holes in everything..! |
17th Jan, 2010 at 06:13:13pm
I've got new nuts already. I'm really after the centre caps more than anything else. If something is worth doing, it's worth doing half of. |
825 Posts Member #: 2208 Post Whore Essex |
17th May, 2011 at 08:26:32pm
these are the one im after, the hole go's all the way through. as i have small spacers, im thinking of fitting longer studs, as im not happy with the way they are at the mo.
On 17th Jan, 2010 Asphalt said:
The nuts in the picture are not the correct type for a Special wheel! The Special wheel's nuts have a STEEL washer which holds them on the car... The ones pictured look like Rover 12" steel wheel nuts with the plastic washer. Special wheel need these: http://images.forum-auto.com/mesimages/251...15a-2.jpg1..jpg Part n° GAW115A :) Cheers, Jan |
7th Jan, 2014 at 11:33:58am
Anyone got any centre caps laying around? If something is worth doing, it's worth doing half of. |
1425 Posts Member #: 9199 Post Whore Lancashire |
7th Jan, 2014 at 02:42:58pm
On 7th Jan, 2014 John said:
Anyone got any centre caps laying around? What the mind can conceive the mini can achieve
7th Jan, 2014 at 02:51:54pm
Indeed. There are some aftermarket alloy ones out there but I want gen if I can find em. If something is worth doing, it's worth doing half of. |
7th Jan, 2014 at 03:02:23pm
http://www.comp.co.uk/products/product.asp...-2-5-cap-x4-2-3
7th Jan, 2014 at 04:27:37pm
I may be tempted as mine are Carl Specials lol no pun.
7th Jan, 2014 at 05:03:15pm
Have a look at Hazpalmer's estate it has them in. If something is worth doing, it's worth doing half of. |
Page: |
