Home > 998cc > 998 sc drops wanted
garrett3
Member #: 7904
Nelson mandela tower,Peckham, Norfolk
as above in gc please *happy*
Ben H
Member #: 184
Melton Mowbray, Pie Country
Good luck they are rare. The second hand ones I have seen recently have gone for not much less than new ones. The other option is to get 1275 drops and double bush them. I have not seen or had this done, but it is a good option if you have a friendly machinest.
http://www.twin-turbo.co.uk
garrett3
Member #: 7904
I just thought I would try my luck and see what happens *happy*
http://cgi.ebay.co.uk/Mini-Cooper-Jack-Kni...=item3ca95dbe28
Looks like A ones to me.
t3gav
Member #: 229
Gavin@minispares.com
kent
Snap...
garrett3
Member #: 7904
there are no good for me then?
graemec
Member #: 1424
Carnforth, Lancs
Doesn't seem to be able to make up his mind whether they are A or A+
Garrett - these will be fine for you if you have an A series gearbox and transfer case.
The A+ used a larger diameter shaft (and hence larger bearings in the casings) for the idler gear.
t3gav
Member #: 229
kent
Just ask him to measure the shaft to make sure :)
garrett3
Member #: 7904
Will ask, what should it be?
He will not disclose the ratio to me so I guess this is probably going to be too difficult for him lol
graemec
Member #: 1424
Carnforth, Lancs
A+ is a 7/8" (22.23m) shaft diameter, A is 3/4" (19.05mm).
I would agree with the others that these are A judging by the amount of bearing surface around the shaft.
Even if they are A ones, they will fit in an A+ box.
Let's all ask him about the ratio. :)
gregh55
Member #: 3636
herefordshire
garrett3, PM Harber07 on TMF he has a set in his engine, and hes going for a vaux engine. . . he might sell them
worth a try
graemec
Member #: 1424
Carnforth, Lancs
Or I could sell you a NOS A series casing *wink*
Edited by graemec on 22nd Jan, 2010.
Can you count the teeth in the pic? I haven't looked yet.
bigmini998
Member #: 2830
Costa del Northern Ireland :)
Mini speed get them in now and then, I got a set for my 998 i think they are a 1275 set with a new bush fitted..
That mini is determined to Kill me!!!!
