Page: |
Home > FAQ / Knowledge > will gungum stop exhaust manifold leak? | |||||||
83 Posts Member #: 6003 Advanced Member |
27th Dec, 2009 at 08:35:56pm
leak between turbo and manifold..if i put some gungum on it , will it do the job? what is the max working temp for gungum? |
1733 Posts Member #: 1910 Post Whore Wilts |
27th Dec, 2009 at 08:56:47pm
I'd say it was a bodge, fix it properly.
the pissed up clown stood back up, did a twirl and left bollock naked, |
1745 Posts Member #: 375 Post Whore Leicestershire |
27th Dec, 2009 at 09:12:55pm
It hasn't worked for me in the past. I had the exhaut housing and manifold surface ground and then just bolted them together without a gasket. Not had any problems since! |
27th Dec, 2009 at 09:18:50pm
On 27th Dec, 2009 Star Mag said:
It hasn't worked for me in the past. I had the exhaut housing and manifold surface ground and then just bolted them together without a gasket. Not had any problems since! you mean it work?or just ground the face then bolted them Edited by jom on 27th Dec, 2009. |
27th Dec, 2009 at 09:54:51pm
No the gum gum cracks and falls out! |
2909 Posts Member #: 83 Post Whore Glasgow, Scotland |
12th Jan, 2010 at 09:18:09pm
i have used a good quality silicone selant for this joint on my car before and worked fine. however, it is a bodge, fix it with a proper gasket.
12th Jan, 2010 at 09:19:15pm
oh ps.. rover on the coupe turbo's had NO gasket between turbo and manifold, jsut both machined perfectly flat. no sealant, and no gasket. As per starmag :) turbo 16v k-series 11.9@118.9 :)
3004 Posts Member #: 2500 Post Whore Buckinghamshire |
13th Jan, 2010 at 04:03:14am
If you really have to, use Firegum instead of GunGum, but its still not the proper answer. |
4890 Posts Member #: 1775 Post Whore Chester |
13th Jan, 2010 at 11:40:20am
same as Evo, I have used high temp RTV, but its a bodge, I bet the manifold is out of sorts... I now use an SC stainless manifold, but then I'm not using a turbo. I run a supercharger and I don't care the TB is on the wrong side.
1596 Posts Member #: 8027 Post Whore Thrapston, Kettering, Northants NN14 |
26th Jan, 2010 at 06:33:08pm
i have always found it heats up, goes hard and works its way off/out when using it :) On 17th Feb, 2011 apbellamy said:
I popped my first one out the other day... |
26th Jan, 2010 at 08:10:58pm
I always had problems with this joint. I used to use exhaust wrap, metal self amalgamating stuff, then a bit of gungum too.
3588 Posts Member #: 655 Post Whore Northern Ireland |
26th Jan, 2010 at 11:47:45pm
why not just fix it properly ? 9.85 @ 145mph
27th Jan, 2010 at 08:42:50pm
I could just never get mine to seal, no matter what I did.
Page: |
